0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 45 | I bought a used steamer/washer that I can't seem to get pumping. Are there any tricks to get it flowing? I have turned the spring-loaded valve, but that only seems to put a load on the pump. It spat out a little water when I tried it after replacing the pump motor(electric) but won't move any water when it's all connected. TIA
All you can do is all you can do.
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Probably have air in the system. I always have it all hooked up with the water running and pull the nozzle out of the end of the wand. Pull the trigger and let the air bleed out first. Then start it up. | | | | | Joined: Apr 2011 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 45 | Thanks for the reply. It did not have a hose or nozzle on at the time I tried it. Do you think the pump requires backpressure to work?
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | | | |
