0 members (), 101 guests, and 2 robots.
Topics128,062
Posts1,055,857
Members48,428
#741048 04/20/2011 9:17 PM
I bought a used steamer/washer that I can't seem to get pumping.
Are there any tricks to get it flowing? I have turned the spring-loaded valve, but that only seems to put a load on the pump. It spat out a little water when I tried it after replacing the pump motor(electric) but won't move any water when it's all connected.
TIA
All you can do is all you can do.
Probably have air in the system. I always have it all hooked up with the water running and pull the nozzle out of the end of the wand. Pull the trigger and let the air bleed out first. Then start it up.
Thanks for the reply. It did not have a hose or nozzle on at the time I tried it. Do you think the pump requires backpressure to work?
yes
Moderated by  MNSmith
