1 members (Shade Baby),
152
8
Mod | | | Forums66 Topics128,106 Posts1,056,214 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | Anyone know where I can find a patch panel for the LH toe board where the floor high beam light switch is located? '65 C10.
Tom 1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
| | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | I guess the deafening silence answers this question.
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I guess the deafening silence answers this question. Hah! Did you try Jim Carter, LMC,and the rest?
Drew
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Get a piece of light metal and fab your own. | | | | | Joined: Sep 2001 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2001 Posts: 36 | Toeboard is misleading, the dimmer switch is on the floorboard and along side the floorboard is the kick panel. A toeboard is found on a scaffold to keep things from rolling off. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Stan - see your assembly manual, on a vehicle the toeboard is the angled panel between the flat floorboard and the firewall [which the factory calls the "dash panel" inside], see here, floor and toe patches are availabe for 47.2-59, don't seem to be available for the 41-47 or the 60's trucks also on a scaffold, the "toe board" can be called a kick board, helpful to keep you from stepping off the edge  Bill | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Hey Tom. I sent you a PM, if you still need help with this part, regardless of what it is called. | | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | Gosh, I love this site! You guys are the best. Bill, thanks, you are seeing what I was seeing, they call it the toe board. By the way before I bothered you guys I've looked at all of them, Jim Carter, LMC, Classic Parts, blaa, blaa, blaa....none of them have this section for the '65 truck. Why? I don't know because it seems to me that it is a perfect rust site.
I cut it out today because it is holding me up. Will see if Tony has something that can help.
Thanks for the replies!
| | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | Go to a wercking yard and cut one out from a old truck floor board. A simple fix. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ... also Tractor supply has a bin where there is several types,or thicknesses in small sheets. If you can use that then use the otherwise shipping cost and buy it local....just a thought. | | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | Don, I've called a bunch of yards locally and they all tell me they don't keep stuff that old anymore. (go figure) I could probably find one a few hours away in some of the yards but my guess is being from the Midwest they'll be just as rusted through as mine. I'll make the calls it is worth a try.
Achipmunk, my next move is to check with a few of the sheet metal contractors I know (HVAC ductwork companies) and see if one of their guys can fabricate something for me. I really want something that has the pressed impression for the dimmer switch that the original did. Maybe I'm being too picky, it's not like I'm doing everything totally original anyway. If not I can easily cut and bend something myself. It's the pressed in part that is hanging me up.
Thanks guys!
| | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | send me an email with a pic of the piece you need, i have a 60 might be the same, if its good on mine i'll cut it out and send it to you! need any other parts let me know! | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Hey Tom. Thanks for your business. I should be able to remove, package & ship the floorboard/toeboard piece tomorrow or Monday. Take care and let me if I can help you with other good, used '60-'66 Chevy/GMC truck, Panel or Suburban parts in the future. | | |
