BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,776 Posts1,039,271 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Mar 2011 Posts: 936 'Bolter | 'Bolter Joined: Mar 2011 Posts: 936 | Just started running low on my first tank thu my 51 which still has its original 216 so I pulled into a station and a zz top lookin old timer who was chatting me up about his old AD farm truck told me I could just use regular 87 unleaded pump gas as I was adding a lead additive ... is this true?
Thanks!
Also how many gallons is the tank? | | | | Joined: May 2006 Posts: 8,351 'Bolter | 'Bolter Joined: May 2006 Posts: 8,351 | 87 octane will be fine. No real need to add any lead additive, which I don't beleive is even available anymore, or a substitute unless you're working the engine hard. IIRC, the tank is 18 gallons for the in-cab tank.
Bill Burmeister | | | | Joined: Mar 2011 Posts: 936 'Bolter | 'Bolter Joined: Mar 2011 Posts: 936 | The previous owner gave me a half case of lead additive in little bottles the look similar to the ones typical injector cleaner or octane booster come in. I guess I can pitch it. ...or what ever you do these days with that type of stuff. lol. | | | | Joined: Feb 2005 Posts: 469 Shop Shark | Shop Shark Joined: Feb 2005 Posts: 469 | I've been running premium in my older stuff to get away from the corngas. It;s a little easier on fuel pumps and carb parts and keeps a little longer in the tank for the ones that set unused for long periods of time. | | | | Joined: Jul 2004 Posts: 2,946 'Bolter | 'Bolter Joined: Jul 2004 Posts: 2,946 | If it sits unused for extended periods, add some Sta-Bil or similar product. The shelf life of modern gas is not that great. | | | | Joined: Oct 2003 Posts: 445 Shop Shark | Shop Shark Joined: Oct 2003 Posts: 445 | gas today is fine.Cost more to make leaded gas,always has.Then why was it cheaper that unleaded gas years ago? You figure that one out.Big brother
dan-pa
| | | | Joined: Nov 2000 Posts: 1,927 'Bolter | 'Bolter Joined: Nov 2000 Posts: 1,927 | gasoline... seriously, our old low-compression engines do not require anything special about the fuel. Many comment about the ethanol/alcohol and how it can deteriorate some seals, gaskets and rubber parts, but it won't hurt your 216. Since the "corngas" as some call it IS NOT going away, and in fact some states have mandated higher percentages of it in gas, we will have to get used to it, and replace/upgrade seals, etc. to handle it...
Professional Novice
| | | | Joined: Feb 2001 Posts: 4,109 'Bolter | 'Bolter Joined: Feb 2001 Posts: 4,109 |
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | Joined: Jun 2010 Posts: 32 New Guy | New Guy Joined: Jun 2010 Posts: 32 | There is a website called www.pure-gas.org and they have a state by state breakdown of where to buy ethanol free gas. If you find one in your area you can submit it to them, and they will add it to the list once they verify it. There are 90+ stations in Texas that are ethanol free. And over 2800 nation wide according to the site. I have been talking to every gas station owner and employee that I run into about trying to get it. I know I'd drive 20 or so miles to get some. I tell them they could really boost their business if they had it. I've seen it in oklahoma advertised as such, and for roughly the same price for the corngas crap I gotta buy in Waco, Texas. I don't know how easy it is to get it at a station, but I'm sure trying. I've got a '65 Mustang that HATES it, and I use Water Remover by STP and Seafoam, and she runs a lot better. Figure I'll do the same to my truck when she's finished. Of course my truck will be a daily driver so I probably won't have to worry as much. | | | | Joined: Nov 2008 Posts: 65 Wrench Fetcher | Wrench Fetcher Joined: Nov 2008 Posts: 65 | Isn't water remover just straight ethanol? | | | | Joined: Oct 2003 Posts: 445 Shop Shark | Shop Shark Joined: Oct 2003 Posts: 445 |
dan-pa
| | | | Joined: Nov 2000 Posts: 1,927 'Bolter | 'Bolter Joined: Nov 2000 Posts: 1,927 | The ethanol debate is so politically charged and there is so much disinformation about it out there that I think many of us have a "received opinion" about it: we believe what we are told to believe... some of us are prejudice against it maybe for the wrong reasons. Cars have been run on alcohol since Model T days. When I visited Brazil in 1992 approx 60% of the cars ran on alcohol made from sugar cane. I don't know what the percentages are today. Back to the original question of what fuel you should run; your 216 will run just fine on straight gas or the E10 blend that is so common everywhere. I run mine on the cheapest pump at the station. With some tuning and re-jetting of the carb it would probably run fine on E85. Though admittedly with some less power and fuel mileage as alcohol has less BTU's per gallon than gas.
Professional Novice
| | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | Shop Shark Joined: Jan 2005 Posts: 1,602 | I've been running regular 87 Octane for four years without problems in my 51. | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | Shop Shark Joined: Jun 2005 Posts: 1,756 | methanol can't be run without some serious re-jetting Plus if you are bothered by $4.00 gasoline, wait until you price methanol and it accompanying 4mpg
Or were you just pulling my leg?
