5 members (MickeyP, Phak1, Steveoreno, Waveski, 54farmtruck), 75 guests, and 0 robots.
Topics128,188
Posts1,057,332
Members48,469
#735861 04/03/2011 3:53 PM
Anyone know where I can find a patch panel for the LH toe board where the floor high beam light switch is located? '65 C10.
Tom
1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
Nesto426 #737642 04/09/2011 2:27 PM
I guess the deafening silence answers this question.
Tom
Nesto426 #737656 04/09/2011 3:16 PM
Hah! Did you try Jim Carter, LMC,and the rest?
Drew
DrewP #737689 04/09/2011 5:22 PM
Get a piece of light metal and fab your own.
Nesto426 #737692 04/09/2011 5:59 PM
Toeboard is misleading, the dimmer switch is on the floorboard and along side the floorboard is the kick panel. A toeboard is found on a scaffold to keep things from rolling off.
rossboss #737732 04/09/2011 9:10 PM
Stan - see your assembly manual, on a vehicle the toeboard is the angled panel between the flat floorboard and the firewall [which the factory calls the "dash panel" inside], see here, floor and toe patches are availabe for 47.2-59, don't seem to be available for the 41-47 or the 60's trucks
also on a scaffold, the "toe board" can be called a kick board, helpful to keep you from stepping off the edge wink
squeeze #737734 04/09/2011 9:27 PM
Hey Tom. I sent you a PM, if you still need help with this part, regardless of what it is called.
Gosh, I love this site! You guys are the best. Bill, thanks, you are seeing what I was seeing, they call it the toe board. By the way before I bothered you guys I've looked at all of them, Jim Carter, LMC, Classic Parts, blaa, blaa, blaa....none of them have this section for the '65 truck. Why? I don't know because it seems to me that it is a perfect rust site.
I cut it out today because it is holding me up. Will see if Tony has something that can help.
Thanks for the replies!
Tom
Nesto426 #739830 04/16/2011 11:19 PM
Go to a wercking yard and cut one out from a old truck floor board. A simple fix.
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
Don G. #739856 04/17/2011 12:59 AM
... also Tractor supply has a bin where there is several types,or thicknesses in small sheets. If you can use that then use the otherwise shipping cost and buy it local....just a thought.
Achipmunk #739918 04/17/2011 4:49 AM
Don, I've called a bunch of yards locally and they all tell me they don't keep stuff that old anymore. (go figure) I could probably find one a few hours away in some of the yards but my guess is being from the Midwest they'll be just as rusted through as mine. I'll make the calls it is worth a try.
Achipmunk, my next move is to check with a few of the sheet metal contractors I know (HVAC ductwork companies) and see if one of their guys can fabricate something for me. I really want something that has the pressed impression for the dimmer switch that the original did. Maybe I'm being too picky, it's not like I'm doing everything totally original anyway. If not I can easily cut and bend something myself. It's the pressed in part that is hanging me up.
Thanks guys!
Tom
Achipmunk #741213 04/21/2011 1:07 PM
send me an email with a pic of the piece you need, i have a 60 might be the same, if its good on mine i'll cut it out and send it to you! need any other parts let me know!
DThela #741498 04/22/2011 4:34 AM
Hey Tom. Thanks for your business. I should be able to remove, package & ship the floorboard/toeboard piece tomorrow or Monday. Take care and let me if I can help you with other good, used '60-'66 Chevy/GMC truck, Panel or Suburban parts in the future.
