6 members (dunfire, Bill Hanlon, stlcardinalsguy, Otto Skorzeny, papas52, Wayne67vert), 121 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
Fixin' to change the gear oil in the differential (and do some inspection of ring and pinion) and was wondering what type of gasket adhesive to use - and do both cover and housing get adhesive?
If it's a good quality gasket you should be able to use it without any adhesive,
If you are using a gasket, use motor oil. I use gasket maker pookie without a gasket.
....if for any reason you plan to pull it back off anyway soon I'd glue the gasket to the cover. Then you can reuse it...with maybe a little gasket maker pookie smile
I've always had good results using Blue Hylomar JMO.
More pix on Flickr.
IMO those paper diff gaskets are obsolete. Just squirt a bead of RTV around the cover, and be sure to make a circle of RTV around each bolt hole. Anything Permatex brand is a good bet.
1951 1/2 Ton 216ci 4spd
1955 3/4 Ton NAPCO 235ci 4spd
1959 1/2 Ton stepside 235ci 4spd
pookie ?? I thought she was one of them Jersey rednecks! You must mean dookie. May try some yellow dookie on the cover with a gasket. Thanks guys!
They are not obsolete on an original truck.
And if you want something that will seal it an not leak, and its not as fussy about a film of oil like any silicon sealer is, use permatex no 2. I don't uses RTV much at all and never on an old original truck.
Why? Chevrolet didn't use it on them.
How do you treat the gasket? I just installed a new fuel pump on my 51 and sprayed the paper gasket with that copper spray.
I treat is nice, and it acts nice for me, !!! I really don't know what you meant???? I don't spray anything on them. If its something you don't want to leak permatex it.
I guess the inner edge could be treated with shelac, or a film of sealer, is that what you are refering to?
RTV
