8 members (68ironhead, lumbersawyer, 48jim1ton, Woodcmiami, 3B, J Lucas, Ponchogl, 1 invisible),
97
0
Mod | | | Forums66 Topics128,049 Posts1,055,553 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 46 | I am the proud owner of a 51 GMC 3 window shortbed and a 51 GMC 5 window long bed. My question is.... Can I put the 5 window Cab on the shortbed frame. I am assuming that the Cabs are the same size and only the frame is the difference, therefore, as long as the short bed is on the short frame the Cab should work. Any info is appreciated.
1951 GMC 3 window 100 1951 GMC 5 window 100
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | No problem. Cabs are the same. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | They are the same cab. The VIN tag is on the cab though. It will show that it is a long box. | | | | | Joined: Aug 2010 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 46 | Thanks builder, i'm aware of that. Not sure that's an issue to me. at least in the muscle car world, cloning is not what it once was thought of. If it's a nice set of wheels and done right.......who should care? I don't.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The DOT might, depending on how the truck is registered. If the title has the engine number on it, and that engine is still in the truck (common on pre-'55), you should be fine. But if it's titled off the serial number from the cab, and you swap cabs without swapping the serial number, that can be considered the same as falsifying the vehicle identity. While it isn't as critical from a value standpoint for an old truck, there's been several high profile (Boyd, West Coast Customs) shops that have been busted for doing just that.
Bill Burmeister | | | | | Joined: Aug 2010 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 46 | thx longbox......food for thought......will ask the almighty DMV !
| | | | | Joined: Mar 2011 Posts: 6 New Guy | | New Guy Joined: Mar 2011 Posts: 6 | I am a new stovebolt member. I don't have a clue as to how to post questions about restoration of my '53 3800. Would someone please tell me I am in the wrong place and how to get to where I want to be. Thank You..... | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Hi TerTer. Welcome to the Bolt.
For these trucks, you have come to the right place. I would suggest to you to start with a Gallery entry. Tell the tale of why you bought your truck and what you want it to be when you are done. Also, don't be ashamed of the shape it's in now. Rust free or basket case, you will get answers here. Once you've done that, a short description of what kind of shape it is in (running, not, rusty, not, dented, not, etc.) and what you would like it to be in General Truck Talk will get you a bunch of answers from which to pick and choose. Also, put the year, make and model of your truck in your "Signature" line (under Profile), so readers will know what you are talking about if you forget it in a post. Good Luck! You're gonna love it!
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | if you get it wrong the all seeing enforcer, uh moderator, will let you know. they are pussy cats so don't worry.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Aug 2008 Posts: 38 'Bolter | | 'Bolter Joined: Aug 2008 Posts: 38 | If both trucks are now registered by the engine numbers it will make it easier but you still should jump through the flaming hoops to make sure that you have everything squared away with the dmv.
Step one would be to go talk to your states dmv and if they have a vehicle inspection station run by the state it would be better to talk to the inspectors first to see what they want from you. Here locally the inspections are done by people who either are or work for the state patrol and that is the best place to get a straight answer.
If you have titles to both vehicles it shouldn't be a problem except for the paperwork.
48 Chevy 3100 going back together with a 292 six and AX15 five speed.
| | | | | Joined: Aug 2010 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 46 | I have both titles and the trucks are both registered (in Calif.). I have a Highway Patrol Inspector friend who probably can tell me what the DMV (which stands for Delirious, Mentally challenged, and Vacated) would want. He identified the authenticity of the vehicles since they have been registered for 30+ years. Thanks Mr48chev and all who contribute. This site is priceless!!
