Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (Shade Baby), 21 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#733947 03/28/2011 3:01 PM
I'm trying to get some physical dimensions to see if I can swap a chevy 6 into another vehicle that has limited room. Googling has given me some conflicting results, such as "235s are longer than 216s", and "the blocks are all the same size", but I can't find any actual numbers for length, width, height. Length from the back of the block to the front of the crankshaft pulley is probably the critical one for me. Can anyone point me to a reference, or go out in the garage and measure one for me? Thanks.
Hello jbrock,
Is this close to what you need?
It includes the length of the bell housing and fan.
6 cylinders
jbrock,
Your critical dimension, from the back of the block to the front of the crankshaft pulley, is about 31-1/4", on a 1961 261. The water pump and fan will add a couple of inches, depending upon the use of a short or long water pump. The height from the bottom of the oil pan to the top of the carburetor air horn is about 30".
Hoyt
