BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
10 members (TUTS 59, homer52, Guitplayer, Hotrod Lincoln, 32vsnake, Charles in CA, Peggy M, 46 Texaco, 2 invisible),
556
robot. | Key: Admin,
Mod | | Forums66 Topics126,776 Posts1,039,271 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Jun 2001 Posts: 775 Bondo Artiste | Bondo Artiste Joined: Jun 2001 Posts: 775 |
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver 1946 Chevy COE - Might restore one day... 1959 GMC Half ton long bed NAPCO | | | | Joined: Jun 2001 Posts: 775 Bondo Artiste | Bondo Artiste Joined: Jun 2001 Posts: 775 | I would go with grade 8 bolts to mount not the stainless he mentions in the aution...........
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver 1946 Chevy COE - Might restore one day... 1959 GMC Half ton long bed NAPCO | | | | Joined: Jan 2009 Posts: 120 'Bolter | 'Bolter Joined: Jan 2009 Posts: 120 | That is John Romero's ebay store. He's a member here and sells on the market place | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | For $110 I think I"d go to Lowes and buy some 3/4 flat steel and bend my own in a vise!! ...and stop at Ace Hardware on the way home for the bolts washers and pins!
| | | | Joined: Jan 2009 Posts: 120 'Bolter | 'Bolter Joined: Jan 2009 Posts: 120 | For $110 I think I"d go to Lowes and buy some 3/4 flat steel and bend my own in a vise!! ...and stop at Ace Hardware on the way home for the bolts washers and pins! Exactly what i was thinking | | | | Joined: Jun 2001 Posts: 775 Bondo Artiste | Bondo Artiste Joined: Jun 2001 Posts: 775 | Never said it was a great deal. But it is a good deal. If you think you can properly form those brackets with just a bench vice your sadly mistaken. Better practice with some junk metal first.
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver 1946 Chevy COE - Might restore one day... 1959 GMC Half ton long bed NAPCO | | | | Joined: Jun 2009 Posts: 118 Wrench Fetcher | Wrench Fetcher Joined: Jun 2009 Posts: 118 | I did mine with a shop press, that works much better. I tried the vice at first and they looked bad. With the press they are exactly like originals.You do need to find a piece of steel the correct width to place in the middle as you are pressing, I don't recall the width though. | | | | Joined: May 2010 Posts: 24 New Guy | New Guy Joined: May 2010 Posts: 24 | just remember they also take a pivot pin.....then a 1/4 inch bolt. | | | | Joined: Sep 2010 Posts: 42 Wrench Fetcher | Wrench Fetcher Joined: Sep 2010 Posts: 42 | If there is enough of a demand ( like around 10 people). I will fabricate them for everyone. I have fabricated them for mine and they look original. I can include them with hardware if you need me too.
Please follow-up on this via email and/or PMs.
| | | | Joined: Sep 2006 Posts: 335 Shop Shark | Shop Shark Joined: Sep 2006 Posts: 335 | Personal Buying & Selling should take place via PM and/or email.
Last edited by tclederman; 04/03/2011 3:55 PM. Reason: message deleted and explanation posted
