1 members (3800GUY),
78
Mod | | | Forums66 Topics128,186 Posts1,057,309 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 35 New Guy | | New Guy Joined: Dec 2010 Posts: 35 | Does anyone know where I can get a rebuild kit for my original water pump. It is for a 265 V8 from a 55 S2.
Thanks. | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy remohbill, I have never seen a rebuild kit for a water pump, the rebuilders seem to have a direct pipeline to the bearing/seal suppliers. You should be able to get whichever F.L.A.P.S. you prefer to supply a rebuilt pump, you might have to wait a few days for it to come in, hope that helps. | | | | | Joined: Dec 2010 Posts: 35 New Guy | | New Guy Joined: Dec 2010 Posts: 35 | I thought they used to rebuild them back in the day. Mine has a plate on the back and it looks like it would be easy to do. Thanks for the taking the time to answer. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | For $8 to $15 for a replacement, I don't think I will go through the trouble myself. | | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | I have rebuilt plenty of pumps for antique engines where commercially-built items were not available. Trust me on this- - - - -if an already-built pump is available, use it! The carbon/ceramic mechanical seal that's commonly used in water pumps is exceptionally fragile, (and expensive) and I've gone through two or three at times before one worked right. The really old ones with the gland nut and graphite-impregnated rope packing are a lot more user-friendly. Jerry
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Advance Auto
Driveworks Pump 58-129 $24.99 or .............58-137 $14.99 or..............58-403 $23.89
if not in stock they can get you one overnight...no shipping!!! | | |
