7 members (Hotrod Lincoln, HandyAndy, Bill Hanlon, FAST55, Charles in CA, John L., ronsway),
122
8
Mod | | | Forums66 Topics128,077 Posts1,056,015 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 35 New Guy | | New Guy Joined: Dec 2010 Posts: 35 | My 37 has 2 different wiper arms/blades and I'm not sure they are correct. The drivers side has an electric motor and the arm is attached to the shaft with a screw. The passenger side is not connected to anything inside the truck (no linkage to the other wiper) and this arm just pushes on to the shast similar to late model arms. Is this correct or has this been altered prior to my ownership? | | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | Originally the wipers ran off vacuum, not electric and most only had one.
1937 Chevy 1/2 ton panel 1953 GMC 2 ton. future car hauler
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...and yes, the wiper blade arm was installed and a nut was screwed down on it. The nut had a rounded "cap head" and would screw down through the arm onto the stem that comes through from the eide. My 37 had on right side windshield wiper but the inside plate was there to install one if I wanted. Sounds like someone had fitted one in yours or maybe installed some type of aftermarket.... although my electric aftermarket had a "stem" on it just like the original. Hope this helps. | | | | | Joined: Feb 2000 Posts: 5,213 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,213 | I have seen one where there was link across the glass to the right arm coming from the left arm. Both arms worked off one motor. And as stated, they were vacuum motors, no electrics were ever installed for years to come.
Joe | | |
