1 members (Otto Skorzeny), 85 guests, and 1 robot.
Topics128,162
Posts1,056,941
Members48,458
#721704 02/17/2011 6:56 AM
I replaced my gauges months ago and finally started looking at the non-working fuel gauge. Wires are all good . Removed the new sending unit, didn't get the 0 to 30 OHM'S. Took the second nut loose from the sending unit to gauge wire. The grommets were letting the stud ground it out . Put the sending unit back together works great with 0 to 30 ohm test. Gauge still doesn't work. I have the 2nd RUNTZ voltage reducer first, one burned. My question is: Would that burn out the fuel gauge ? Tested it myself, just checking to see what readings I should have? Turn ignition switch on, gauge reads "E" then moved down a hair more lower.
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
Too much currentr or amps is the reason why your voltage reducer smoked. Reason for hi current is unknown. Could be operator error or a failed component like wiring insulation. On the other hand. One very common mistake is a mismatch between what your gauge wants to see, resistance wise, from your sender and what ohms value sender you installed. BTW, there are many pervious posts on this subject with a number of troubleshooting hints to help solve the problem.
Same thing happened to me with the Runtz resitor it heated and shorted out to the back of the gauge. I am using the original sending unit (1950 truck) but I gounded the tank to the cab like the 52-and later trucks (wire from one of the sender screws to cab brace). I could never get it to work until I bought a new 12-volt gauge from Classic Parts works like a champ now. I also was really careful when I installed it to use new cardboard seperators like the original on the back of the gauge. They are available from www.classicchevroletparts.com but I couldn't find the item number this morning.
The vendor also told me they had a bad batch of the voltage reduers and sent me a new one.
I wouldn't of had all this trouble if they would of sent me a 12 volt fuel gauge and let them keep the RUNTZ voltage reducer.Changing the gauge is about my least favorite thing to do on the truck.The cardboard was installed on the gauge when it was sent to me rebuilt.
http://s897.photobucket.com/albums/...00/?action=view&current=IMG_0910.jpg
Thank you for your input.
Lesson here is don't use the voltage reducers.Use the 12 volt gauge pieces when you can. http://secure.oldchevytrucks.com/FU...53-GMC-WHITE-NEEDLE/productinfo/RESP260/
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
