| | | Forums66 Topics128,162 Posts1,056,944 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | I replaced my gauges months ago and finally started looking at the non-working fuel gauge. Wires are all good . Removed the new sending unit, didn't get the 0 to 30 OHM'S. Took the second nut loose from the sending unit to gauge wire. The grommets were letting the stud ground it out . Put the sending unit back together works great with 0 to 30 ohm test. Gauge still doesn't work. I have the 2nd RUNTZ voltage reducer first, one burned. My question is: Would that burn out the fuel gauge ? Tested it myself, just checking to see what readings I should have? Turn ignition switch on, gauge reads "E" then moved down a hair more lower.
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Too much currentr or amps is the reason why your voltage reducer smoked. Reason for hi current is unknown. Could be operator error or a failed component like wiring insulation. On the other hand. One very common mistake is a mismatch between what your gauge wants to see, resistance wise, from your sender and what ohms value sender you installed. BTW, there are many pervious posts on this subject with a number of troubleshooting hints to help solve the problem.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Same thing happened to me with the Runtz resitor it heated and shorted out to the back of the gauge. I am using the original sending unit (1950 truck) but I gounded the tank to the cab like the 52-and later trucks (wire from one of the sender screws to cab brace). I could never get it to work until I bought a new 12-volt gauge from Classic Parts works like a champ now. I also was really careful when I installed it to use new cardboard seperators like the original on the back of the gauge. They are available from www.classicchevroletparts.com but I couldn't find the item number this morning. | | |
