1 members (qside),
28
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 292 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 292 | how far back do i have to move my axle to center my wheels in fender on 51 3100
thanks
john | | | | | Joined: Dec 2009 Posts: 292 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 292 | thank for the quick reply! | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If I had known this was a double post I would have deleted it instead of moving it here. | | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | Let me get that straight since I am about to change the rear in my 52. When I put the camaro rear end in there, it should be 1 1/2 inches further back than the stock placement for the wheels to be centered?
'52 3100 "once a Marine, always a Marine!! | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | why a camaro rear end, it is a truck Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | I moved my'n back 1 1/5" and it looked great.
layback
| | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | I moved my'n back 1 1/5" and it looked great. Is that like the metric equivalent?  | | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | Funny ha ha ..you got me . should be 1 1/2"
layback
| | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | Would that 1 1/2 inch also apply to a 38 1/2 ton?
1937 Chevy 1/2 ton panel 1953 GMC 2 ton. future car hauler
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | goneagain, I believe the 37/38's are the same. On my 37 which I put a Malibu rearend under, it was 1 1/2 inch. I simply made a flat plate, drilled a hole to set it over the spring center pin, then moved 1 1/2' from that hole, drillesd and tapped that hole and threaded in a Hex head bolt in it. Then the perch block set down over that bolt. Simply and works fine.
I won't say yea or nay on this but there has been much talk here in the past about just turning the springs around end to end and then it'd be right. I turned them around on my 52panel but there is a couple things to deal with if you do.... as the springs are built "off set" because of the "swiveling rearend". Its a long story but if you want to know call me!! | | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | Thanks Alvin, I like the plate idea. I'm using a nova rear end so I have to add to the spring perches any way.
| | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | I picked up a set of perches at the trailer store pretty cheap and just the right size.The center bolt hole was larger so i welded in a 1/2" washer to match.
layback
