4 members (TooMany2count, MNSmith, moparguy, TexasJim50), 56 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#719736 02/10/2011 1:13 AM
how far back do i have to move my axle to center my wheels in fender on 51 3100
thanks
john
#719739 02/10/2011 1:16 AM
thank for the quick reply!
#719754 02/10/2011 1:47 AM
If I had known this was a double post I would have deleted it instead of moving it here.
Cletis #720030 02/11/2011 2:16 AM
Let me get that straight since I am about to change the rear in my 52. When I put the camaro rear end in there, it should be 1 1/2 inches further back than the stock placement for the wheels to be centered?
'52 3100 "once a Marine, always a Marine!!
Panhead59 #720072 02/11/2011 3:58 AM
why a camaro rear end, it is a truck
Redryder pix
My Hotrod
#720122 02/11/2011 11:44 AM
I moved my'n back 1 1/5" and it looked great.
layback
Is that like the metric equivalent?
smile
1946 Chevy 1/2-Ton
More pix on Photobucket
Sometimes I forget where I left myself....
andy46 #720341 02/12/2011 11:37 AM
Funny ha ha ..you got me . should be 1 1/2"
layback
laybacklenny #720348 02/12/2011 12:19 PM
Would that 1 1/2 inch also apply to a 38 1/2 ton?
1937 Chevy 1/2 ton panel
goneagain #720407 02/12/2011 4:49 PM
goneagain, I believe the 37/38's are the same. On my 37 which I put a Malibu rearend under, it was 1 1/2 inch. I simply made a flat plate, drilled a hole to set it over the spring center pin, then moved 1 1/2' from that hole, drillesd and tapped that hole and threaded in a Hex head bolt in it. Then the perch block set down over that bolt. Simply and works fine.
I won't say yea or nay on this but there has been much talk here in the past about just turning the springs around end to end and then it'd be right. I turned them around on my 52panel but there is a couple things to deal with if you do.... as the springs are built "off set" because of the "swiveling rearend". Its a long story but if you want to know call me!!
Achipmunk #720597 02/13/2011 5:33 AM
Thanks Alvin, I like the plate idea. I'm using a nova rear end so I have to add to the spring perches any way.
goneagain #720643 02/13/2011 1:46 PM
I picked up a set of perches at the trailer store pretty cheap and just the right size.The center bolt hole was larger so i welded in a 1/2" washer to match.
layback
