2 members (Southerntruck, Hush),
150
Mod | | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | The reproduction rubber fender pads for the 47-55 1st series COE trucks do not have the metal frame that bolts to the fender. Should one bond the reproduction pads directly to the fender or would it be better to bond to the old metal frame and then bolt that to the fender, like it was originally? Does anyone have any experience with this?
Kent | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I will be bonding the rubber pads to the metal frames (I do not yet know what I will bond them with).
| | | | | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | Just had this conversation last weekend, My plan is to bond them to the frame but I'm not sure how yet either, will be interested in seeing the response to this. Mongo | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | When I restored my 1935 Chevy Coupe I used Weldwood Contact Cement to glue the running board rubber to the backing plate. I followed the instructions on the can, put a thin coat on both pieces and they are still attached looking as good as new 30 years later! Mike B  | | |
