| | | Forums66 Topics128,160 Posts1,057,050 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 98 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 98 | I was told that the AD truck & suburban frames are the same. with the exception of a few more body mounts on the suburabn, panel frame? Is that the short bed frame? thanks in advance.
1952 Chevy Suburban 1964 Chevy Suburban 1965 Chevy Suburban 4X4 1941 Chevy Truck 1948 Sedan Delivery 2000 K2500 Suburban 2008 K1500 Suburban
Run with the dogs or [censored] with the puppies
| | | | | Joined: Feb 2008 Posts: 320 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2008 Posts: 320 | That is generally true. For detailed info you can find some at the GM Heritage center Lots of good basic info on all GM trucks there. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Perro, There were only 1/2 ton suburbans during A-D Advance-Design years (47-55). All A-D 1/2 ton trucks came in one wheel-base (116"). As you stated, there are different body mounts on the 1/2 ton panel-body frames (plus a few extra reinforcement "gussets"). Also, the 1/2 ton frames were different in different years. 1954/55 frames were different from earlier years but the differences might not be important, except for the lack of brackets for panel-body mounting blocks. Also, 1953 and earlier 1/2 ton frames had an extra frame cross-member for the mount at the rear of the transmission. What year frame and/or body are you looking to put together? Here is a direct link to GM Heritage Center resources by year. | | | | | Joined: Jan 2006 Posts: 98 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 98 | I had a friend ask me, And i remember reading something here. Just trying to educate myself, and increase my knowledege.Thanks Perro
| | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Tim, Wasn't there a one ton panel?
Weeds | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Weeds,
Yes, there were 1-ton Panel and Canopy Express trucks/frames from 1947-1955.
I thought the question was directed to a Suburban, which only came as a 1/2 ton.
I probably should have also posted that there was no "short bed" vs "long bed" 1/2 ton Chevrolet Advance-Design trucks (47-55); however, there were short-bed and long-bed New Design GMC pickups in those same years.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Weeds, don't mean to butt in here but I think what Tim was saying is no 1 ton Suburbans?? There are 1 ton panels.
| | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | So a 1949 ad SHORT bed frame will fit under my 1949 suburban and are these mentioned body mounts something that needs to be welded on or drill hole and bolt thru the frame? | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | So a 1949 ad SHORT bed frame will fit under my 1949 suburban and are these mentioned body mounts something that needs to be welded on or drill hole and bolt thru the frame? Yes Tony, the frames are virtually the same. Body mounts, rear floor mounts and the gas tank mounts are different. The 1949 frame will have the knee action shocks and mounts and the 1951 and later will have the tube mounted shocks and brackets. | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | So a 1949 ad SHORT bed frame will fit under my 1949 suburban and are these mentioned body mounts something that needs to be welded on or drill hole and bolt thru the frame? Yes Tony, the frames are virtually the same. Body mounts, rear floor mounts and the gas tank mounts are different. The 1949 frame will have the knee action shocks and mounts and the 1951 and later will have the tube mounted shocks and brackets.They are just bolt on stuff correct? i have the part to swap from knee action to tube shocks already so im set there | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | So a 1949 ad SHORT bed frame will fit under my 1949 suburban and are these mentioned body mounts something that needs to be welded on or drill hole and bolt thru the frame? Yes Tony, the frames are virtually the same. Body mounts, rear floor mounts and the gas tank mounts are different. The 1949 frame will have the knee action shocks and mounts and the 1951 and later will have the tube mounted shocks and brackets.They are just bolt on stuff correct? i have the part to swap from knee action to tube shocks already so im set there Had to dig up this old topic got a 51 1/2 shortbed frame for my 49 suburban going to start working on it i know gas tank mount for sure is different but can some one point out EXACTLY what frame body mounts are different? is it just redrilling holes in the frame? | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | The gas tank location has some frame mounts and bolts that you will need to transfer from your frame. The suburban has two large body mounts and I believe that the frame has the holes pre drilled in the frame already. You will also have to use the bed support from your suburban. That's the extent of the differences between the truck and suburban frames. By crawling under your 1949 you can see the mounts for the gas tank, the bed and the body. I think that the only one you cannot remove with the body on is the bed supports. Removing the other mounts won't be easy with the body on, but I am sure you can do it.
The 1949 and the 1951 spare tire carriers are different too. | | |
