2 members (Ponchogl, 1955 1 Series), 376 guests, and 4 robots.
Topics128,163
Posts1,057,044
Members48,463
I was told that the AD truck & suburban frames are the same. with the exception of a few more body mounts on the suburabn, panel frame? Is that the short bed frame? thanks in advance.
1952 Chevy Suburban
1964 Chevy Suburban
1965 Chevy Suburban 4X4
1941 Chevy Truck
1948 Sedan Delivery
2000 K2500 Suburban
2008 K1500 Suburban
Run with the dogs or [censored] with the puppies
That is generally true. For detailed info you can find some at the GM Heritage center Lots of good basic info on all GM trucks there.
1951 Chevy 1-Ton Panel
Pictures of the restoration on Photobucket
RIP good friend.
Perro,
There were only 1/2 ton suburbans during A-D Advance-Design years (47-55). All A-D 1/2 ton trucks came in one wheel-base (116").
As you stated, there are different body mounts on the 1/2 ton panel-body frames (plus a few extra reinforcement "gussets").
Also, the 1/2 ton frames were different in different years. 1954/55 frames were different from earlier years but the differences might not be important, except for the lack of brackets for panel-body mounting blocks. Also, 1953 and earlier 1/2 ton frames had an extra frame cross-member for the mount at the rear of the transmission.
What year frame and/or body are you looking to put together?
Here is a direct link to GM Heritage Center resources by year.
I had a friend ask me, And i remember reading something here. Just trying to educate myself, and increase my knowledege.Thanks
Perro
1952 Chevy Suburban
1964 Chevy Suburban
1941 Chevy Truck
1948 Sedan Delivery
2000 K2500 Suburban
2008 K1500 Suburban
Tim, Wasn't there a one ton panel?
Weeds
Weeds,
Yes, there were 1-ton Panel and Canopy Express trucks/frames from 1947-1955.
I thought the question was directed to a Suburban, which only came as a 1/2 ton.
I probably should have also posted that there was no "short bed" vs "long bed" 1/2 ton Chevrolet Advance-Design trucks (47-55); however, there were short-bed and long-bed New Design GMC pickups in those same years.
Weeds, don't mean to butt in here but I think what Tim was saying is no 1 ton Suburbans?? There are 1 ton panels.
So a 1949 ad SHORT bed frame will fit under my 1949 suburban and are these mentioned body mounts something that needs to be welded on or drill hole and bolt thru the frame?
Stovebolt CHEVROLET
1949 Chevrolet Suburban
Non stovebolt CHEVROLET
1958 Impala Convertible
1963 Impala Convertible
MY 1949 SUBURBAN
Yes Tony, the frames are virtually the same. Body mounts, rear floor mounts and the gas tank mounts are different. The 1949 frame will have the knee action shocks and mounts and the 1951 and later will have the tube mounted shocks and brackets.
They are just bolt on stuff correct? i have the part to swap from knee action to tube shocks already so im set there
Stovebolt CHEVROLET
MY 1949 SUBURBAN
Had to dig up this old topic got a 51 1/2 shortbed frame for my 49 suburban going to start working on it i know gas tank mount for sure is different but can some one point out EXACTLY what frame body mounts are different? is it just redrilling holes in the frame?
Stovebolt CHEVROLET
MY 1949 SUBURBAN
The gas tank location has some frame mounts and bolts that you will need to transfer from your frame. The suburban has two large body mounts and I believe that the frame has the holes pre drilled in the frame already. You will also have to use the bed support from your suburban. That's the extent of the differences between the truck and suburban frames. By crawling under your 1949 you can see the mounts for the gas tank, the bed and the body. I think that the only one you cannot remove with the body on is the bed supports. Removing the other mounts won't be easy with the body on, but I am sure you can do it.
The 1949 and the 1951 spare tire carriers are different too.
Thanks G i think these are the mounts your refereing too the angle iron looking one there is one on pass and driver side of the frame sorry about the small pics i couldnt get them to resize
Suburban body/frame mount at rear arch
Suburban body/frame L bracket one on drivers and pass sides
I found another pic with all 3 braces in one and i think i fixed the sizing isssue
SUBURBAN BODY/FRAME BRACKETS ALL IN ONE PIC
andbody have these brackets? or know where i can get them so i can attach them to my shortbed frame im building to swap my suburban onto
Stovebolt CHEVROLET
MY 1949 SUBURBAN
