6 members (tesa, RAC1812, Gdads51, Gray_Ghost, artinva, RdsLessTaken), 63 guests, and 0 robots.
Topics128,077
Posts1,055,928
Members48,430
Thought I'd introduce myself, since I just acquired a Canadian-made 1950 1/2 ton. Had a break in the weather and drove it home on Thursday when it was 60F (it's now about -5F with wind chill of -20F).
My wife said that I could have any truck I wanted as long as it was older than I was, so this is my project.
The truck is pretty much original. It's been repainted, but retains its 6V electricals, drivetrain, suspension and brakes. Interior's been restored, but it seems to be reasonably correct for the period. The wood in the bed is in black, and nothing seems out of place underneath.
This also translates to a few expected issues - the rear main "seal" doesn't, the transmission seals don't, and the fuel line flex hose at the tank drain leaks. Ho-hum...
I'm looking forward to learning from the folks on this board - it really is a great resource. Thanks to jockbolter50 and Big Chevy 3600 for their kind words.
Here are a few photos - I'll add more soon:
FCutten's album
Cheers,
Fraser
Cheers,
Fraser
1950 Chevrolet 1300 1/2 ton (Built in Oshawa)
http://1950Chevy.blogspot.com
Leo Offline
Moderator
Moderator
welcome Fraser, hope you have a nice warm shop to work in.
Leo
welcome you are in good company
*UNDER CONSTRUCTION*
1953 Chevrolet 3100 1/2 ton-previously abandoned resto.
My Project Bolt
I hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
BRrrrrr, hope your warm. Welcome to the Bolt.
Nice looking truck!
Welcome to the Bolt!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Hi Fraser,that's a sharp looking truck!
You're 'better half' sounds like a great lady too.
Hang on to them both! grin
More pix on Flickr.
Welcome, Fraser, nice pics!!
Thanks for the welcome - it's amazing that this post has been viewed 148 times already.
I've been able to set up a blog to chronicle what I'm doing (or, more truthfully, planning to do) with the truck. Any feedback would be very welcome.
http://1950chevy.blogspot.com/
Cheers,
Fraser
Cheers,
Fraser
Welcome from up the road. If you get a need for speed and want to upgrade the ring and pinion Canadian trucks are a little different and require additional machining of the carrier. PM me if you want details.
You Tube
Fraser,
Nice looking truck.
Curt,
What is different on a 1950 Canadian Chevrolet truck that requires machining when doing a swap to (presumably ?) a 3.55 R&P (it is always interesting to hear what oddities you northerners have to deal with)?
Tim,
The bolt hole circle on a Canadian carrier/ring gear is 3/16" larger than that found on U.S trucks so the options are:
1. Obtain a carrier from the U.S. (Patrick Dykes will suggest this as he has probably never seen a Canadian carrier and would not have had a comparison opportunity.)
2. Machine the correct bolt circle which will elongate the holes 3/32" towards the center. ( A BC bolter took his to a machine shop and paid an outrageous amount to have it done)
3. As the existing spotface diameter is acceptable carefully elongating the holes with a rat tail file would probably work and I was told by Scott's Super Trucks that some customers have done it that way succesfully.
Here's a few pic's:
http://rides.webshots.com/album/573906758RqiOTm
You Tube
Nice to see a fellow Canadian with such a nice truck... looking forward to seeing more of it here! smile
One last post from me for this forum.
I've not done a restoration before, but I think the disassembly/reassembly process may be a little more difficult than how these Canadians get er done with a Willys jeep:
Cheers,
Fraser
Cheers,
Fraser
