7 members (Gdads51, texas46, Otto Skorzeny, TUTS 59, Ponchogl, klhansen, greenie-reddy),
136
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 51 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 51 | I have a 1 ton panel that is missing the gears in the differential all thats there are the axles, how do i find out what goes back in, i cant find any numbers
1950 one ton panel, 1959 half ton apache
| | | | | Joined: Apr 2010 Posts: 245 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 245 | Check the "Freebees" there's a free one in Utah! | | | | | Joined: Feb 2000 Posts: 69 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 69 | Get yourself a 3/4 ton third member, it will fit perfectly and give you much better performance on the road at lower rpms.
ron | | | | | Joined: Jan 2011 Posts: 51 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 51 |
| | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | Uncleb is right! The gear ratio in your truck was very low, probably in the "5's". This means you will probably cruise at 45 mph.
I think the 3/4's were in the mid 4's like about 4.55.
A lot depends on your future use plans for the panel truck. | | | | | Joined: Jan 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 60 | Uncleb is right! The gear ratio in your truck was very low, probably in the "5's". This means you will probably cruise at 45 mph.
A lot depends on your future use plans for the panel truck. tdplbg,I have a 3600 3/4ton,I just replaced the rearend to an S10 4WD w/373gears posi trac. The original gears were 5:14,and the previous owner change the pig to 4:56gears.If you weren't so far away,I would let have the whole rearend at reasonable offer. Just thought I would chime in.I am located in Piqua,Ohio.Thanks | | | | | Joined: Apr 2000 Posts: 199 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 199 | Z71, what offset rims are you running? I found the 4x4 rear end was still too narrow in my son's '54 pickup truck so have 2" spacers added. Did you get the ZR2 rear end (noticing the Posi)? That one is supposed to be wider than the standard 4x4.
I worked at Evenflo 11 years ago in Piqua. | | |
