6 members (Otto Skorzeny, Gdads51, 55shaker, Woogeroo, 78buckshot, dt235sd), 168 guests, and 4 robots.
Topics128,268
Posts1,058,379
Members48,485
#712710 01/17/2011 6:48 PM
I have a 1 ton panel that is missing the gears in the differential all thats there are the axles, how do i find out what goes back in, i cant find any numbers
1950 one ton panel, 1959 half ton apache
tdplbg #712716 01/17/2011 7:15 PM
Here's a link to the service manual specs which lists everything you are missing.
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0447.htm
Good luck!
1958 GMC Suburban Carryall
Never accept a drink from a urologist!
Check the "Freebees" there's a free one in Utah!
68ironhead #712815 01/18/2011 1:35 AM
U
U Offline
Get yourself a 3/4 ton third member, it will fit perfectly and give you much better performance on the road at lower rpms.
ron
uncleb #713111 01/18/2011 11:59 PM
thank you all
tdplbg #713498 01/20/2011 9:55 AM
Uncleb is right! The gear ratio in your truck was very low, probably in the "5's". This means you will probably cruise at 45 mph.
I think the 3/4's were in the mid 4's like about 4.55.
A lot depends on your future use plans for the panel truck.
Murraydave #714792 01/24/2011 9:40 PM
Z
Z Offline
tdplbg,I have a 3600 3/4ton,I just replaced the rearend to an S10 4WD w/373gears posi trac. The original gears were 5:14,and the previous owner change the pig to 4:56gears.If you weren't so far away,I would let have the whole rearend at reasonable offer. Just thought I would chime in.I am located in Piqua,Ohio.Thanks
Z71Chevy #714860 01/25/2011 1:44 AM
Z71, what offset rims are you running? I found the 4x4 rear end was still too narrow in my son's '54 pickup truck so have 2" spacers added. Did you get the ZR2 rear end (noticing the Posi)? That one is supposed to be wider than the standard 4x4.
I worked at Evenflo 11 years ago in Piqua.
Just here for the free beer.
1953 1-Ton Dump Truck
1954 Teenage Hot Rod
