2 members (delky, UtahYork),
144
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,195 Posts1,057,375 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#71263 01/06/2007 11:59 PM | Joined: Dec 2006 Posts: 12 Junior Member | | Junior Member Joined: Dec 2006 Posts: 12 | '1967-'72 6 cyl in my 1949 3100? I had the one bbl in it rebuilt but it is not original to the engine.
Thank you for any suggestions. This forum has already been a great help. | | |
#71264 01/07/2007 2:20 AM | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Give these guys a call. http://www.thecarburetorshop.com/ They can help ya with pretty much anything. | | |
#71265 01/07/2007 2:39 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | autozones cheepest.thats where i boght one for a 235 | | |
#71266 01/07/2007 4:15 AM | Joined: Dec 2006 Posts: 12 Junior Member | | Junior Member Joined: Dec 2006 Posts: 12 | Thank you both very much. | | |
#71267 01/07/2007 6:46 AM | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Hey Lee, I would go new if it can be afforded. Rebuilts just don't seem to measure up with any carbs out there....that is unless you are willing to unbolt a few and return until you get the right one, or get lucky. | | |
#71268 01/07/2007 4:56 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | What model carb. do you have? The 67 used the Roch. model B & the 68 up used the monojet. I,m with Tomcoe, The over the counter remans are seldom good. Of all things don,t turn in your old carb. untill you are satisfied with the on you got. What is wrong with the one that was rebuilt? They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#71269 01/07/2007 5:03 PM | Joined: Oct 2005 Posts: 29 'Bolter | | 'Bolter Joined: Oct 2005 Posts: 29 | Lee, I bought a Holley-Weber 2 barrel from Tom Langdon's Stovebolt engine co. for my GMC 270 and it works great. Be sure to buy his linkage kit. Runs well, modest improvement in power from the 1-barrel. | | |
#71270 01/07/2007 5:35 PM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Ditto on the Holly/Weber from Langdon's. I bought an AutoZone rebuilt Rochester...$109. opened the blister packed carb in the store, only to discover the choke circuit had been incorrectly installed. The manual choke would not even close. I took this as a "sign". Bought Tom's H/Weber setup. Out-of-the-box it was great...the truck runs, and idles like a swiss watch. Tom's setup was a few dollars more...you'll probably want to spring the $12. for the water choke heat to 12 v electric conversion. I would highly recommend his setup if you are interested in improved drivability. I've got pics of the carb and linkage setup in my webshots "shoebox". Hope this helps. | | |
#71271 01/07/2007 7:01 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | nice truck,enjoyed the pix... Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#71272 01/07/2007 11:11 PM | Joined: Feb 2004 Posts: 29,882 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,882 | Has anyone adapted the 2GC Rochester to the Stovebolt engines? I'm thinking a slight manifold flange modification to a 4-bolt, 2-barrel base flange wouldn't be terribly difficult, and one of the small-bore 2-barrels like the 265's and 283's used would be about the right CFM. The 261 I'm planning to build would probably benefit from a setup like that. Jerry
#71273 01/08/2007 2:42 AM | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | To LeeW Try Mountian man fuel systems at [email protected] I bought a carb from him off of Ebay and I got to say it was the best rebuilt Carb I ever bought I "just bolted it on" and it ran awesome !! I didnt have to make any adjustment at all Top notch builder good luck Todd Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | |
#71274 01/08/2007 12:01 PM | Joined: Dec 2006 Posts: 12 Junior Member | | Junior Member Joined: Dec 2006 Posts: 12 | The carb I had rebuilt still seeps ever so slightly around the gasket in the middle. The linkage need replacing anyway and this was the second or third or fourth rebuild on this carb before I go it, I am sure. I just know that this carb is going to be trouble. It is nice to have a bit later engine which I am sure is a recent rebuild. I am thinking of A/C (I am in Florida) after a repaint and so I want to settle any performance issues first. Thanks. | | |
#71275 01/08/2007 2:23 PM | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | Where can you buy brand new Roch Bs or Carter YFs? I've only seen remanufactured units available. What is the going price? Remans seem to run ~$100.
My carb is showing the exact same issues as Lee's, and I want the problem to disappear. Any thoughts on B versus YF (besides what was originally installed.)
I hope to buy a carb in the next 10 days, so this topic has particular interest for me.
Thanks for any input.
Bill | | |
#71276 01/08/2007 8:30 PM | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | If the linkage needs replaced that is one thing. If you have excessive play in the throutle shaft then you may have a vacuum leak.
The seaping gasket is evidence that the float is set just a little too high. Gas shouldn't "rest" on the gasket. It should rest below the gasket just slightly or any gasket on any carb will seap. They aren't "liquid tight". Just resistent to sloshing and keeping gunk out. | | |
#71277 01/08/2007 10:34 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Contact Carbking. He is on this websight alot & is very helpful. Send it to him & he will rebuild it & test it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#71278 01/08/2007 10:44 PM | Joined: Dec 2006 Posts: 12 Junior Member | | Junior Member Joined: Dec 2006 Posts: 12 | | | |
