6 members (52Carl, Stovebolt48, Southerntruck, Wayne67vert, baldeagle, cmayna), 156 guests, and 1 robot.
Topics128,195
Posts1,057,380
Members48,471
Junior Member
Junior Member
'1967-'72 6 cyl in my 1949 3100? I had the one bbl in it rebuilt but it is not original to the engine.
Thank you for any suggestions. This forum has already been a great help.
Give these guys a call.
http://www.thecarburetorshop.com/
They can help ya with pretty much anything.
My 1953 Chevrolet
1947.1 Gallery
Z
Z Offline
autozones cheepest.thats where i boght one for a 235
Junior Member
Junior Member
Thank you both very much.
Hey Lee, I would go new if it can be afforded. Rebuilts just don't seem to measure up with any carbs out there....that is unless you are willing to unbolt a few and return until you get the right one, or get lucky.
When I yield to Him, it's amazing how peaceful and enjoyable life is meant to be.
1947 Chevy COE
Riding in the Passing Lane
What model carb. do you have? The 67 used the Roch. model B & the 68 up used the monojet. I,m with Tomcoe, The over the counter remans are seldom good. Of all things don,t turn in your old carb. untill you are satisfied with the on you got. What is wrong with the one that was rebuilt?
1972 Chevy c10 Cheyenne Super
Lee, I bought a Holley-Weber 2 barrel from Tom Langdon's Stovebolt engine co. for my GMC 270 and it works great. Be sure to buy his linkage kit. Runs well, modest improvement in power from the 1-barrel.
Ditto on the Holly/Weber from Langdon's. I bought an AutoZone rebuilt Rochester...$109. opened the blister packed carb in the store, only to discover the choke circuit had been incorrectly installed. The manual choke would not even close. I took this as a "sign". Bought Tom's H/Weber setup. Out-of-the-box it was great...the truck runs, and idles like a swiss watch. Tom's setup was a few dollars more...you'll probably want to spring the $12. for the water choke heat to 12 v electric conversion. I would highly recommend his setup if you are interested in improved drivability. I've got pics of the carb and linkage setup in my webshots "shoebox". Hope this helps.
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
nice truck,enjoyed the pix...
Fred
Redryder pix
My Hotrod
Has anyone adapted the 2GC Rochester to the Stovebolt engines? I'm thinking a slight manifold flange modification to a 4-bolt, 2-barrel base flange wouldn't be terribly difficult, and one of the small-bore 2-barrels like the 265's and 283's used would be about the right CFM. The 261 I'm planning to build would probably benefit from a setup like that.
1 Offline
To LeeW
Try Mountian man fuel systems at [email protected]
I bought a carb from him off of Ebay and I got to say it was the best rebuilt Carb I ever bought I "just bolted it on" and it ran awesome !! I didnt have to make any adjustment at all
Top notch builder
good luck
Todd
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
Junior Member
Junior Member
The carb I had rebuilt still seeps ever so slightly around the gasket in the middle. The linkage need replacing anyway and this was the second or third or fourth rebuild on this carb before I go it, I am sure. I just know that this carb is going to be trouble. It is nice to have a bit later engine which I am sure is a recent rebuild. I am thinking of A/C (I am in Florida) after a repaint and so I want to settle any performance issues first. Thanks.
Where can you buy brand new Roch Bs or Carter YFs? I've only seen remanufactured units available. What is the going price? Remans seem to run ~$100.
My carb is showing the exact same issues as Lee's, and I want the problem to disappear. Any thoughts on B versus YF (besides what was originally installed.)
I hope to buy a carb in the next 10 days, so this topic has particular interest for me.
Thanks for any input.
If the linkage needs replaced that is one thing. If you have excessive play in the throutle shaft then you may have a vacuum leak.
The seaping gasket is evidence that the float is set just a little too high. Gas shouldn't "rest" on the gasket. It should rest below the gasket just slightly or any gasket on any carb will seap. They aren't "liquid tight". Just resistent to sloshing and keeping gunk out.
1947 Chevy COE
Contact Carbking. He is on this websight alot & is very helpful. Send it to him & he will rebuild it & test it.
Junior Member
Junior Member
Thanks!
