10 members (Bill Hanlon, Possum, MickeyP, KEVINSKI, 3800GUY, NorCal52Suburban, Joe H, 55shaker, Paul Mullen, 1 invisible),
127
Mod | | | Forums66 Topics128,108 Posts1,056,558 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#70293 12/19/2006 12:38 AM | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | I put new points and set the gap at .019". I replaced the cap, condenser and plug wires. I set the plug gap at .035". I timed the engine at 4 deg BTDC. I rebuilt the carb. Started it and it idles great. But when I give it gas, it starts to miss at higher RPM. I tried driving it down the road, but again, it ran like it's missing or with no power. This is the first 6 cyl I've tuned so don't know what to do next?? | | |
#70294 12/19/2006 12:48 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | well if it starts and idles ok, then that is a plus.. have you been tinkering with the carb? how was it running before you replace the items that you speak of. done anything to the dist, like move it? clean fuel filter? any cracks in the fuel lines? gas tank got any trash in it..
not the it makes much difference, what type of vehicle is this... engine, yr... Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#70295 12/19/2006 1:20 AM | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | Hi Seon,
Did you check the timing with the advance disconnected and plugged and at low idle? May pay to check if the advance is working when you increase the revs.
Cheers mate
Bob | | |
#70296 12/19/2006 1:38 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Seon,
I'm thinking along the same lines as Mozzie. You indicate you timed it 4° BTDC, and I wonder how you came to that value. Do you have a advance timing light or did you read some little numbers off a plate near the distributor.
The carburetor has a powervalve in it that gives the engine extra fuel when you mash the gas. Although pretty simple to overhaul, if one little ball isn't where it belongs, or a spring is hanging up, things won't work right.
The carburetor to manifold gasket is directional. It must have the slot positioned under a vacuum sensing hole in the carburetor base. Look around a bit more and give us some good news.
Stuart | | |
#70297 12/19/2006 1:47 AM | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | I recently bought this '59 from the original owner that has low miles but hadn't ran for a long time. I changed fluids, replace all the ignition parts along with new gas tank, sender and fuel hoses, started it up and engine idled smooth but was missing when rev'd. Thinking that it may be the carb, I rebuilt it. While the tank was out, I blew the gas line out to clear it with 95 psi from the gas tank end thru to the other end while the line was disconnected from the fuel pump. I've installed a new gas filter in carb and an in-line clear filter just before fuel pump. Started it, again, idled great but misses at higher RPM. I did put a timing light on it and set timing at 4 deg BTDC by disconnecting the vacuum line and plugging the line and carb. I checked and doubled check the firing order 1-5-3-6-2-4. I check the distributor vacuum which is operating correct. This is not a my first time tuning an engine... but this is my first 6 cyl tune up :rolleyes: BTW I did notice that when rev'ing the engine the lower portion of the distributor did rotate but returned when letting off the gas...is that suppose to do that :confused: . | | |
#70298 12/19/2006 2:21 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Seon,
It sounds like your vacuum advance is working just the way it was designed to. You know what you are doing so finding the problem shouldn't be horrible.
Valves that are gummy and sluggish from a long nap could be a contributing factor to your miss.
The task at hand is to determine if the miss is being caused by carburetor issues, or ignition problems.
Is the miss a occasional miss or is the engine totally crapping out. If it isn't backfiring through the carburetor, can you slowly choke the air horn with your hand as you bring it up in RPM and see if the extra fuel brings it out of its spasm.
This will tell you it goes lean off idle and might be a float setting issue.
Bring the RPM up very slowly and see where you get into the 'crappy' area.. is it mid throttle or pushing full throttle.
What happens when you road test it under load, does it act differently, or is this not possible running as it is.
I would set the timing back to the factory marks for now. You can always tweek it later.
Stuart | | |
#70299 12/19/2006 6:10 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Is your fuel pump okay? A weak/dying pump can make it run exactly like that.
Also, I wonder about the filter in front of the pump. Your pump can handle chunky gas, and should tha filter plug up, you could burn that pump up. Most of us have our filters just before the carb. I'm not saying you should move it, it's just an FYI. | | |
#70300 12/19/2006 1:17 PM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | You can tune a piano and you can tune a fish but you can't tune a stovebolt without adjusting the valves. Just a reminder. Tom | | |
#70301 12/19/2006 3:33 PM | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | The fuel filter in front of the pump shouldn't restrict the fuel pump but I'll remove it to see if it cures it. Regarding valve adjustment, are they hydraulic or if solid lifters, what's the setting? If those two things don't work, I'll replace the fuel pump :confused: | | |
#70302 12/19/2006 9:19 PM | Joined: Nov 2006 Posts: 61 Member | | Member Joined: Nov 2006 Posts: 61 | What if your coil is breaking down on ya? I`ve had it happen on other Chevies and on Harleys. Also i had a 230 six that had a bearing out in the distributor, allowing the rotor to wobble and misfire. Just thinking out loud. Please let us know what you find,. Have a fun day today. Slider
Jesus is Love! Never forget the Veteran. AND God bless Amercia!
#70303 12/20/2006 6:44 AM | Joined: Aug 2005 Posts: 39 New Guy | | New Guy Joined: Aug 2005 Posts: 39 | Check whether the dwell angle changes at higher rpm. Worn bushings in the distributor can do that.
Simplicity leads to reliability.
#70304 12/20/2006 6:15 PM | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | Just to let everyone know, I've stopped working on this for the time being. With the holidays upon us, the wife says she needs me to drive her Xmas shopping  . I'll post after I get back. | | |
#70305 12/21/2006 4:39 AM | Joined: Apr 2005 Posts: 2,099 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,099 | Seon, I recently had a similar problem with a 235 in a 56 Car. It idled great but ran badly off idle and under power. I double checked the float level to specs but it made no difference. I finally tried experimenting with the float level and got it right but it is nowhere near what the specifications called for. Sometimes these things have a mind of their own. Fred
#70306 12/21/2006 5:37 AM | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | My truck was doing similar, only exception is it was freezing the carb where it bolted to the intake. I had the carb apart 6 times before I finally got the speck of gunk in it out that made it run like hell. Id bet the carb has some microscopic hunk of old dirt in.
Ran absolutely beautiful after that! Dont give up, mine persisted this way for weeks ( :mad: looked like this for awhile)and I went through most everything with spark, fuel and timing to.
Blow out all the passages with compressed air in the carb 1 more time, both ways and try her again. Jeff | | |
#70307 12/21/2006 2:10 PM | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | I have no carb or running problems,but wanted to comment on the freezing statement. This is common on these old carbs and is normal. As the gas evaporates along with the pressure difference in the throat of the carb the temperture can drop below freezing and cause frost to form on the outside of the carb.It's normal. | | |
#70308 12/22/2006 8:46 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | When you put the carb back on the engine did you put a gasket between it and the intake? There is a little vacuum passage drilled into the base of the carb that needs to see clear into the intake. A lot of the gaskets in the kits don't include a notch. This keeps the power valve circuit from operating in the carb and causes extremely rich off-idle mixture. If you have a phenolic spacer on the intake you can run the carb with no gasket, or just make sure you cut out the notch with a utility knife.
#70309 12/22/2006 9:14 AM | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | could be bad plug wires or crossed | | |
#70310 12/22/2006 4:31 PM | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | Originally posted by 4ontheFloor: When you put the carb back on the engine did you put a gasket between it and the intake? ... Interesting statement...there was no gasket when I removed the carb before rebuilding it, so I didn't install one :rolleyes: . Could that be my problem?  | | |
