| | | Forums66 Topics128,180 Posts1,057,154 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | I am banned from that site, so I can not view the photos, but I would like to see what you are talking about. The only factory holes I am aware of on the light-duty Chevy/GMC trucks are:
1. 4-speed tranny shifter ('60-'66) 2. 4x4 transfer case shifter ('60-'66) 3. tranny e-brake handle (early 60's) | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | They don't look factory to me, looks like they were made with a big punch and hammer. Somebody suggested access to bell housing bolts but they don't look big enough for that purpose. Besides who would want to disassemble the interior of the truck to change a clutch. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....ask the previous owners!! Does it appear that it is just a punched hole or can you tell if something was ever Bolted there? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Just had this thought. Floor console prior to the floor shifter going in? You are fixing that mess aren't you? | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | 4-5-6 chevy trucks,
I emailed you the link to have a look. Hope it worked.
Drew
| | | | | Joined: Sep 2009 Posts: 21 New Guy | | New Guy Joined: Sep 2009 Posts: 21 | My 64 gmc has the same hole in it , they are for the drain tubes on a aftermarket air conditioner that mounted underdash.It had a drain on each side thats why 2 holes. MIKE | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | I am banned from that site, so I can not view the photos, but I would like to see what you are talking about. Tony: Here is a link to the picture: http://inlinethumb62.webshots.com/47741/2199265080103882008S600x600Q85.jpg.They are for sure factory holes because they are punched from inside the cab and they were under the "factory applied" sound deadener. Sounds like Mike has the answer: air conditioning drain holes.
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Thanks John. Definitely not factory...A/C drain holes gets my vote. | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Thanks John. Definitely not factory...A/C drain holes gets my vote. I am thinking it was factory.... look at this photo http://inlinethumb55.webshots.com/45302/2702918180103882008S600x600Q85.jpg that's factory applied sound deadener, right? The metal under the sound deadener was pristine, as if the tar type material was sprayed on it shortly after the cab was assembled. If the holes are under the factory applied sound deadner how can the holes not also be factory applied?
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Both of mine had shiny fawn painted metal under the tar paper stuff. Somebody shot some undercoating there in the past 40+ yrs, IMO. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | if the a/c was a dealer installation then the dealer would have to had to lift the mats to install the drain lines anyway. the metal would still be pristine and the dealer would have had access to the tar type material as you call it ron | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | Those holes are in the same spots on my 64 c-60, there is a plate behind it that bolts go to your holes look like someone made them bigger., but my cover can be unbolted to and yours does not appear to be bolted but spot welded
