3 members (Gray_Ghost, walter74, 1 invisible),
107
Mod | | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 90 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 90 | I'm not sure if there is a blinker switch for a 38 Chevy pickup originally. I've seen blinker switches on them, but were they there originally or did they use their left arm? Thank you,
Nevada 2010 Chevy | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Most of them was left arm or when available, Clyde for right turns. | | | | | Joined: Sep 2010 Posts: 90 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 90 | So when were they available? I would like to know to where I keep it as original as possible. I don't get the Clyde picture though, thanks
Nevada | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | there were no factory signals in 38, but as signals became common and required by law, many aftermarket units became available and many [most] vehicles were retrofitted ... your truck also wouldn't have had 2 tail lights, gonna stick with that? ... if you think folks nowadays understand hand signals, then try original  Bill | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | You are telling your age. Clyde the orangutan was Eastwoods passenger in a series of movies in the 1970's "Every which way but loose" and "Any which way you can" One of the catch phrases from the movies is "Right turn Clyde" | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Right turn Clyde! Warning! Warning! Offensive gesture in video!
Bill Burmeister | | | | | Joined: Sep 2010 Posts: 90 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 90 | True, didn't think of that.  Well, Jim Carter's Truck Parts has this small toggle switch blinker system apart from the brakes, so I'll just do that since it's small and hardly noticable. Thanks for the help! Nevada 2010 Chevy | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | If you are looking for period correct pieces the are available reguarly on eBay, very cool and very expensive usually. Search in the rat rod stuff you will find them. I did not say Chevrolet correct I said aftermarket period correct. | | |
