5 members (Otto Skorzeny, Wickedbass, Hanks custodian, 32Fordpuchoptop, Gdads51), 67 guests, and 2 robots.
Topics128,094
Posts1,056,048
Members48,433
#698365 11/26/2010 5:37 AM
http://www.flickr.com/photos/71138077@N00/sets/72157624815296278
I have made some progress on my 1.5 ton.
I have replaced the front and rear axle with hydraulic brakes. The front end is from a 1950 and the rear is from a 1/2 ton 1972 four wheel drive. I used springs that was on it so I suppose it would still be a 1.5 ton, though I'm not sure. I found a GMC 235 with a four speed transmission attached so I have that installed. The local welding shop is working on my drive-shaft, it needed a little work before it would fit. It is surprising how well the parts fit together. The engine and transmission fit right in, without modifying anything. The front and rear motor mounts were spaced perfect. The rear end fit right into place. The rear end set right into place as well. I still need to run the brake and fuel lines, finish the wiring, build a bed and floor board then do the upholstery. I haven't decided what color to paint it yet. It was dark blue, but my family wants me to paint it black.
Here is what it looks like so far: http://farm6.static.flickr.com/5170/5207826019_117cd6f593_b.jpg
1956 Chevy 3600
“Maynard”
In the DITY Gallery
More pictures on Flickr
Looks like your doing a bang up job Bart, making all those part fit. You must feel pretty good about that.
I kinda think I would like blue better too.
1951 Chevy 1-Ton Panel
Pictures of the restoration on Photobucket
RIP good friend.
I love that style Bart. Nice job. I think it will be a cool driver with the running gear you put under it. Thanks for saving another piece of Americana!
I had never built a flat bed before. I guess it turned out ok: http://www.flickr.com/photos/71138077@N00/5483728502/sizes/l/in/photostream/
http://www.flickr.com/photos/71138077@N00/5483728482/in/photostream/
1956 Chevy 3600
“Maynard”
In the DITY Gallery
Nice! looks like the kids like it too.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
From what I've seen on some old trucks still working for thier keep, your bed is fine. I personally would want some steel or aluminum framing around the outside, but hey.. thats just me. Given the pile you drug home, I think you've made outstanding progress.
RIP good friend.
Moderated by  John Milliman
