0 members (),
256
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy bigtony55, you will have to come up with a shaft, rag joint, and a column that will end just outside the firewall, that way you will be able to connect to the steering box which you have mounted to the front of the left frame rail. This setup does require a bit of fabrication to complete the installation, and as usual there are many ways to achieve the same result, good luck. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You'll need to cut your old colum and shaft shorter, do a little machine work on the end of the shaft. In the end of the column tube you install a bearing possibly with an adapter bushing. Also make a mount to attach the column to the floor. For the telescoping shaft and joints there are a lot of choices, I'd go with something like these http://www.flamingriver.com/index.php/products/c0008I used joints and a shaft from these folks http://www.borgeson.com/xcart/ and while they work just fine I think Flaming river will have a better quality product, and will try them next time. Don't have a great picture of my setup, but I did use the original column. http://rides.webshots.com/photo/2055030960080251109iezFAOGrigg | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | You'll need to cut your old colum and shaft shorter, do a little machine work on the end of the shaft. In the end of the column tube you install a bearing possibly with an adapter bushing. Also make a mount to attach the column to the floor. For the telescoping shaft and joints there are a lot of choices, I'd go with something like these http://www.flamingriver.com/index.php/products/c0008I used joints and a shaft from these folks http://www.borgeson.com/xcart/ and while they work just fine I think Flaming river will have a better quality product, and will try them next time. Don't have a great picture of my setup, but I did use the original column. http://rides.webshots.com/photo/2055030960080251109iezFAOGrigg Thanks for the info by machine work to you mean cut and grove or notch it or make splines so the joint can grip the smooth round steering shaft? | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | If you get double-D u-joints and intermediate shaft, you just have to grind flats on opposite sides of the original shaft so it fits in the first u-joint. If I'm not mistaken, the rag joint will be on the new steering box, not on the original shaft. I believe kits are available for adapting the original steering column to a modern steering box. They have machined bearings and stop-rings to keep the steering shaft centered in the tube after the original box is cut off. Check with the vendors of the power steering kits.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Thanks for the info by machine work to you mean cut and grove or notch it or make splines so the joint can grip the smooth round steering shaft? Correct, and as mentioned the simplest method is to use a u-joint with what they call a double D end on it, then you simply take the 3/4 shaft and mill flats on opposite sides so it fits, easy to do in the (milling machine) vice and about a 1/2" end mill, just bump both sides in the same setup, and the radius of the mill makes a nice transition back to round. Grigg | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | Would this shaft from cpp work?http://i89.photobucket.com/albums/k237/bigtony55/steeringcolumnshaftadapter.jpg they are running a sale these next 2 days so i wanna order up some stuff from them plus what size is the stock column shaft so i know what size column saver they offer 1.5",1.75" and 2" http://i89.photobucket.com/albums/k237/bigtony55/steeringcolumnshaft.jpg | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Bigtony, I wish I had the link but for now I don't. However, one of the vendor sites has a step by step on doing what your trying to do. It may be Classic Parts or CCP...I'm not sure. If you would check out a couple sites I think the pictures and instructions would help a lot. Worth the try......Mmmm, it may actually be here in the tech tips section...... I'm not at home or I could find the info and tell you right where to look. | | |
