3 members (wilbur53, 2 invisible), 71 guests, and 3 robots.
Topics128,109
Posts1,056,572
Members48,448
#692806 11/07/2010 5:42 PM
Hello, I have two front fenders for my 37 that are pretty rough. I have read alot on here about glass replacements and the two top suppliers seem to be R&R or Superior. Are they the top places as far as quality or are the others. What about Speedway or I&I. Thanks
32cruisin #692818 11/07/2010 6:22 PM
Riding in the Passing Lane
I put 4 on a 40 pickup from R&R and they were real good. They seemed to be priced lower then the rest as they are direct.
1972 Chevy c10 Cheyenne Super
If you use glass, make sure to put a good undercoat on them. They're going to spider web over time and undercoat will slow the process a lot.
Avette4me #692882 11/07/2010 9:53 PM
I know one bolter that had a problem with a R&R rear fender but I must say I've got front/rear/running board fiberglass, from R&R, on my 37 that have held up great for 10 years now. Me personally, I've have had good success with R&R's hand lapped stuff. (guys name is Richard Keller). If you chat with Richard tell him your a stovebolter and ASK for a discount or free shipping and I think he will help you out.
Tell him "da chipmunk" (Alvin) say to call him.
Achipmunk #692962 11/08/2010 2:31 AM
Heard good things about R&R...had an issue with Superior not fitting worth a darn. To their credit, they gave me a full refund without any arguement.
1940 Chevy KC 1/2-Ton
Britcon #693028 11/08/2010 7:26 AM
I put a set of Superiors on, fit lousy up front near the grill, maybe the repro grill was too big, or maybe the fenders were not right or both.
Rears fit pretty well but couldn't get the last 2 bolts in at the rear - had to drill 2 more holes under the bed side flange and put a dummy screw in the hole that missed.
He at least seemed interested in helping me, ultimately didn't really need it. Rear fix was easy, front was solved at the body shop by filling in the large gap between the fenders where they meet the fender extensions.
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
do a search in paint and body shop section under fenders. there is plenty of info, personaly i had major issuses with qaulity and custumer service i wuold not recomend r+r to any one at least 46 pickup rear pickup fenders
jrm4x4 #693075 11/08/2010 2:57 PM
Ex Hall Monitor
Ex Hall Monitor
The main problem with glass parts is the mold they are made from is only good for a limited number of curing cycles. The heat and shrinkage during the cure process cause them to distort. As with any tooling the cost to replace the molds is high so the makers have a tendency to run too many parts before replacing the mold. This results is the mis-fitting parts described above. Assuming the Masters the molds are made from are dimensionally correct, properly braced & stored, a part from a new mold will be far superior to the 100th part out of the same mold.
Tiny #693087 11/08/2010 3:34 PM
I have R&R on the front and really like them. I would get the next ones coated with a bed liner next time, they are a little thin and do get stars in the paint from rocks and what not. What ever you spray on them, do it before painting them.
Joe
Joe H #693102 11/08/2010 4:44 PM
Would you recommend brushing it on yourself or getting it sprayed on?
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
homer52 #693430 11/09/2010 5:22 PM
I would get it sprayed, but do it before painting. We have a company here (Kansas City area) called Amerigaurd bed liner. They can spray anything, even styrafoam, with out hurting it. Its sprayed hot but not enough to hurt the fiberglass. It would be my choice if doing it again.
Joe
