3 members (MickeyP, TexasJim50, 3B), 56 guests, and 7 robots.
Topics128,013
Posts1,055,322
Members48,419
#69110 11/24/2006 10:54 PM
Junior Member
Junior Member
My 235 suddenly, started backfiring at high revs. I've checked or replaced most ignition parts, timing is at the ball, and I've tried moving it and no luck. Two years ago I rebuilt the engine and it has been running great. Last check valves were adjusted. The backfire is a rapid firing and it only occurs accelerating at higher rpms. Any ideas???
#69111 11/24/2006 11:13 PM
Riding in the Passing Lane
Sounds like ign. breaking down. Check the plugs for cracks. Check the plug wires & dist cap.Make shure the points haven,t slip & not opening enough.
1972 Chevy c10 Cheyenne Super
#69112 11/25/2006 12:01 AM
sadams,
Pretty interesting handle!! smile It almost sounds like a intake valve is hanging, or in slow motion with a weak/broken valve spring. I would take another look under the valve cover.
Stuart
#69113 11/25/2006 3:04 AM
Quote
Originally posted by atomarc:
sadams,
Stuart
I assume you were thinking what I thought at first! I think his name is S. Adams, I hope,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#69114 11/25/2006 3:26 AM
my vote is for a valve problem......
#69115 11/25/2006 11:11 AM
Junior Member
Junior Member
It comes from an old American name "Adams". I'll pull the valve cover today, since I've done most of the iginition stuff.
The truck was runnin great, then I installed a BW T-5 tranny (which I love) and then the engine acts up. Try and explain this to my wife.
Stephen
#69116 11/25/2006 1:19 PM
My 58 235 did that one time. Was running fine, driving down the road. Engine had appx 60,000 miles on it. All of a sudden it would back fire when you put it under load, and had a slight miss at idle. I did everything else but look under the valve cover first. Finally found that a pushrod had broken on and exhaust valve. New pushrod, adjusted valves and her she went again.
#69117 11/27/2006 3:29 PM
I had one that did that, after checing timing,points, plugs,wires, i pulled the valve cover to find one valveguide bad.I could hold the valve with my finger while idling and the motor would smooth right out.
#69118 11/27/2006 4:53 PM
Rapid backfiring through the carb is usually caused by an EXHAUST valve being closed, usually due to a pushrod problem. Possible rocker arm adjuster backed off but not likely. For the non-believers, back an exhaust rocker all the way off and rev the engine; it'll sound like a Tommy gun.
Evan
#69119 11/27/2006 7:23 PM
I'll agree with Atomarc.
High revs? bent intake valve, leaking intake valve, floating intake valve, broken intake spring.
#69120 11/28/2006 1:48 PM
My 350 shaby had a slight miss when I would gas it under no load it would rapidly backfire thru carb.Pulled valve cover and noticed a lifter not operating properly.Long story short. Lobe on cam ground to round.
#69121 11/30/2006 6:02 AM
Junior Member
Junior Member
Sorry, no update yet, We've had a bit of a snow storm here in the NW (it doesn't take much to paralyze us)I've been clearing trees instead. Today, I found metal (aluminum shavings) in my 1957 Piper Pacer engine. At least my new 1990 Subaru is still running.
#69122 11/30/2006 12:20 PM
Check your distributor and make sure there isn't too much play in the shaft.
#69123 11/30/2006 1:30 PM
Don't like shavings of any kind in an engine, specaly, aircraft.Sound like teardown time.
