0 members (),
145
Mod | | | Forums66 Topics128,281 Posts1,058,471 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i know this has been covered before as to what to use but should you cover the entire inside of he door? i have the materials but have not done it.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I covered the entire door on my 46. The inside of my dooors were easy to get to, I'm not too sure about the later trucks. So if you can I'd say do the entire door. George | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | not so easy on a 54 12" by 5" panel at the bottom right of the door and a 6x3 at the top left with a regulator in the way.
| | | | | Joined: Jan 2010 Posts: 41 New Guy | | New Guy Joined: Jan 2010 Posts: 41 | what exactly are you using to insulate your doors | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Ron, it depends on what your after. If you just want to hear a solid thud when you close the door, then all you have to do is place a pad in the middle of the panel. The object is to dampen the "drum" effect. The doors, the rear cab panel, the roof or any large relatively flat panel act as a “drum head” where small vibrations are amplified across the entire panel. It’s not necessary to totally cover the entire inside of the vehicle with sound deadener to quiet it down inside If you are looking for thermal insulation then, that’s another story. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Denny, what kind of "pad" do you recommend? Sound deadening adhesive pad? or something else? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I used this stuff sound deadener 32x54 $38.00 roll Not as thick as the expensive stuff but it was easy to apply and afforadable a few pics The supplier is out of Arizona and NOT a chevy supplier. Ive been reading on the forum of some people using peel and seal from the hardware store I did just the center section of the door on my 50 door pic The stuff I used is self stick on a clean surface. Dynamat or Hushmat are probably better but were not in my budget Good luck | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Jon, I played around with some of this and it looks like it will work pretty good. Doesn't have any smell and it doesn't seem to be bothered in direct sun. http://www.pbase.com/dennygraham/image/128491214 Probably similar to Peel and Seal. Denny Graham Sandwich, IL
| | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | ...Denny, I "played around" with some of the same stuff. I put it in the front doors. It did take the tinny sound out of the doors but I'm not sure about how much "insulation" help it is. I'm looking at some other stuff to put on the sides, and overhead of the panel. That thing will get pretty warm in the summer...as well as cold in the winter!! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That's right Alvin, I thought I had posted something about the lack of thermal or sound insulating properties. It is good hoever as a damper for the "drum" effect of large flat panels it that's what one is looking to quiet. Denny Graham Sadwich, IL
| | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | ....you DID post it Denny. I just have short term memory loss and didnt' go back and read all the threads. As always your right on pal. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | I used Reflectex on my 4t6. Pictures start here. Have fun and good luck Dan | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I like old trucks that sound like old trucks... none of this prissy stuff for me, thank you.  | | |
