0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68463 11/12/2006 12:38 AM | Joined: Mar 2004 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2004 Posts: 96 | Hello All,
I am having a serious problem with getting my rear drums adjusted on my '53 3/4 ton. I have brand new drums, used shoes but they have plenty of life left on them. Everything else on the brake assembly is new including the parking cable lines. What is happening is the shoes are tending to drag on the drums with the start gear completely sucked in. I am spinning the eccentric anchor pin around and I can find the point where it pulls the shoes closest together but the problem that I having trouble understanding is what do I do now? I am supposed to be able to adjust the star gear out to get the shoe to touch the drum...seems like they shouldn't be touching as soon as I put the drum on. What are some of the possible problems that could be causing this? Should I replace the shoes? Could they be worn unevenly? It seems like they are dragging pretty uniformly but don't know for sure. Is there a tried and true step-by-step method for doing this...things that I might need to look out for that aren't in the service manual? At this point, I am pretty desperate because this is about the only thing that is holding me up on getting the truck out of the garage after a year and a half. Thanks for any input. I can give further details if it will help...just let me know.
Whad you do?!?
Shane 1953 Chevrolet 3600
#68464 11/12/2006 1:29 AM | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Just to try, take the shoes off and lay them in the drums. If the ends of the shoes contact the drums with a large gap in the middle, I'd say there is a geometry problem and new, compatible shoes are required. If the shoes fit the drums, then something mechanical is the problem, and I have no clue where to go.....
Good luck
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
#68465 11/12/2006 2:10 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Pull the parking brake and/or push on the brake pedal while adjusting brakes, it help to recenter the shoes inside the drum, Scott | | |
#68466 11/12/2006 3:17 AM | Joined: Mar 2004 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2004 Posts: 96 | thanks guys. I like the idea about pulling the shoes and drum to double check the geometry. Simple, visual way to affirm or eliminate that as a possibility. I tried the parking brake trick and it helped bring things in. They are done...knew it wouldn't take long once I got some input. Thanks a lot.
Whad you do?!?
#68467 11/12/2006 1:04 PM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Shane, Where did you get new drums for your 3600? And, are the drums for a '53 the same as the drums for a '50? Denny Graham Sandwich, IL Ok, looked it up in Hollanders and it looks like 47-52 are interchangable, 53 is different.
Denny G Sandwich, IL
#68468 11/12/2006 5:09 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You may have the brake cables too tight. Back off the cable adjustments till you get the other adjustments O.K. then adjust the cables but don,t get them too tight. Some of these old brakes had an adjustable anchor pin. You could loosen the big nut on the back of the backing plate & tap the pin up or down to center the shoes. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#68469 11/12/2006 6:33 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Originally posted by Denny Graham: Ok, looked it up in Hollanders and it looks like 47-52 are interchangable, 53 is different. Yes, 46-52 are the old "Huck" style on 3/4 tons. They put "Bendix" style brakes on them in 1953. If you're looking for new Huck brake drums, Jim Carter has them. | | |
#68470 11/12/2006 8:03 PM | Joined: Mar 2004 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2004 Posts: 96 | Denny,
I bought my drums from Chevy Duty, but the guys are correct, 1953 had the 'new' style Bendix brakes. I have never seen a 'Huck' style drum so I can't comment on how they would be different.
Wrenchbender, according to the factory assembly manual; 1/2 tons have style pin that you are talking about. 3/4 tons have a cam-like anchor pin that changes the pad alignment as you turn it. The back of the pin is 7/16" hex head for those of you that are interested. That is one minor detail that I missed until last night. It was right there in front of my eyes the whole time. I was trying to tap on my pin like it was a half ton.
Whad you do?!?
