| | | Forums66 Topics128,113 Posts1,056,612 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68144 11/03/2006 8:49 PM | Joined: Nov 2006 Posts: 25 Junior Member | | Junior Member Joined: Nov 2006 Posts: 25 | 1966 inline six. The motor smoked the plugs were oil fouled. There was good compression. I took the head off and the valve stems were loose in the guides. I bought the vehicle in this conditon. I had the head rebuilt. The motor still smokes...alot. The plugs have soot on them as I let it idle for an hour but do not have wet oil on them. I noticed drops of oil coming out of the exhaust pipe. I shut the motor off and took the intake exhaust manifolds off. Both the ports on the head and manifold had plenty of oil, enough to wipe onto your fingertip, even the intake. It seems they forgot to put the oil seals on the valve stems. The motor smokes pretty much the same as before I put the rebuilt head on. A few notes. I did not put a straight edge on the block deck. Could the block be warped? I did not use any permatex or silocone on the new head gasket. I torqued the head correctly and have sucessfully done the same job to another six before. In cleaning the tops of the pistons I noticed it is .60 over. I have 140 plus compression in each cylinder and the plugs were not wet with oil. The pvc hose goes back into the intake manifold. I can not imagine blowby can carry this much oil. Is that possible? I am going to clean out the ports on the head, leave the manifolds off and crank the motor to see if oil is coming down the valve guides. Will I get enough oil pressure for this test by cranking or does the motor need to run? Any thoughts will be greatly appreciated. | | |
#68145 11/03/2006 9:59 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Freds,
Welcome to the Stovebolt forum. Great explanation of your dilemma. I am not an expert, but have a few thoughts.
A malfunctioning PCV setup can allow raw oil vapor to enter the intake manifold. Installing a new valve would be a simple step.
I am wondering if your exhaust system is soaked with oil from your previous problems. I have seen a small amount of oil make a rig smoke for hours.
If your compression is as great as it appears, and your PCV system is working properly, I think I would take a long trip down the road and see if the exhaust would eventually burn itself clean.
My bet is all the valve have quad ring seals, you might not see them. The exhaust guide isn't as critical in regards to oil consumption as a intake.
Take a trip, get the system hot and see what happens. Good luck.
Stuart | | |
#68146 11/03/2006 10:37 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | you can do a proper wet / dry compression test.
do the dry one first, mark the findings down. squirt some WD or light machine oil in the plug hole and do the wet compression test. if the wet has better readings.... your rings are bad as the oil helps seal the ring gap.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#68147 11/03/2006 11:09 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Seems to me the oil is coming from the pcv system. Look inside the valve cover. There should be a housing around the area that the pcv valve goes in. Some aftermarket chrome covers don,t have this or it could have broken off at one time. Make shure the valves are adjusted o.k. Loose valves can throw excess oil around. The test you discribe is no good. Try running it with the pcv valve out of the hole & see if the smoke stops. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#68148 11/04/2006 1:07 AM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | If you have a exhaust system full of old oil and suet it may take a while to burn it all out. Did this one time replaced a smokey motor with a fresh one, it smoke like the old one till all the old oil burned out. | | |
#68149 11/04/2006 4:07 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I'm betting you raised the compression against some bad rings, oil rings in particular, and it's actually burning the oil. If it's burning a lot and smoking heavily, it has to be cylinder related. If it's a puff under decelleration then maybe valve seals, but I doubt it from you description. I had a car that the oil rings were stuck due to carbon build up and a timing belt breaking. The rings got compressed into the piston and it ran fine but burnt a quart of oil in 200 miles. I rerung it and it never burned a drop since. Scott | | |
#68150 11/04/2006 4:24 PM | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | I vote for removing the PVC valve from the valve cover and going for a drive. Get it good and hot and drive it prett hard. Valve seals can make it smoke, but they won't oil down a intake, they will oil down the exhaust, but stock 230/250's didn't have seal on the exhaust anyway! Go for a drive and clean out the system befor getting to worked up about it, just leave the PVC out for a bit till you know you got it good and dryed out... Joe | | |
#68151 11/05/2006 5:57 AM | Joined: Aug 2005 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 81 | So I assume this applies the same way after installing new valve cover gaskets also? I got most of the oil build up that was there due to the old gasket leaking however she still smokes like a chimney after a good drive. Most of what is still remaining is what ran down and got on to the exhaust.
Boogity, Boogity, Boogity Let's go racin boys. Drive fast, turn left. GO #20.
Real trucks where bowties.
#68152 11/06/2006 8:20 PM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Oil driping from the tail pipe? Daaaamn! First thought is that the exhaust system is full of oil and untill it all burns out it is gonna smoke. The thing is where or should i say when did the exhaust system fill with oil? With the old head or after the head was replaced? If you dont find any PCV problems and the engine seems to run ok. I would check the oil on the stick and drive this vehicle for 1000 miles then check it again. If it is using oil the level should get low in a 1000 miles. I have also seen an oil bath air filter cause the same thing because it was over filled.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | |
#68153 11/07/2006 7:04 AM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | There are eight ways that I can think of that oil can reach the combutstion chamber from the crankcase. In no particular order-
1. Through a broken or porous diaphragm in the vaccum booster of the fuel pump.
2. Through a defective mechanical, vaccum type crank case ventilator
3. through a ventilating tube connecting valve chamber covers to the air cleaner.
4. Through a leak past the head gasket, seperating an internal oil passage and a cylinder at the top of the block.
5. Through the valve guides.
6. Through a leak past the intake manifold gasket where the manifold covers the tappet chamber.
7. Past the pistons and piston rings.
8. (I don't think you have this, but just incase) Through leakage around the seals of mechanical superchargers or turbochargers.
Being as how you're so lucky, not all of these occur in any one engine.
You can test most of what you need without taking the engine down for an enternal examination.
You can easily check- 1. 2. 3. 4. 5. 6. and 8.
If you would like me to take you through each test please let me know. I will gladly help. Each test will give you a postive out come as to if it is where the problem is.
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
#68154 11/07/2006 5:41 PM | Joined: Nov 2006 Posts: 6 Junior Member | | Junior Member Joined: Nov 2006 Posts: 6 | I just bought a 1970 Truck with an inline 6 (not sure if it is a 250 or 292). It smokes so bad that you can't even drive it. It just pours deep blue smoke, yet it runs strong and sounds great, no rod knock, no overheating, just valve train tapping. I am at a total loss as to why it is smoking so bad!
So your not the only one with a smoking problem, I guess I have the same problem. Perhaps we just need to re-ring our engines? | | |
#68155 11/07/2006 11:30 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | a 292 has 6'' side valve covers, because of the longer stroke of 1.75'', larger volumn H2O pump, distributor @ #2 cylinder, just behind the spin on oil filter which is just below the #1 cylinder
#68156 11/11/2006 10:54 AM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | HuckMubb, you may want to find out 'how' the oil is getting into the crankcase. I wrote a tech tip that you may want to check out- Engine smoking, Tech tip . I hope this can help you and you don't need to rebuild the entire engine.
#68157 11/12/2006 3:17 PM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | "loose" rod bearings can cause excessive oil to be thrown on the cylinder walls, more than the rings can control.
"It ain't a truck if you can't hose out the cab."
#68158 11/12/2006 4:44 PM | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Does your truck have an automatic Trans ? A vacuum modulator that is bad will suck the trans oil out of the pan and smoke like a steam train.If It's a stick shift,do what Wrenchbender Ret. suggested.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
