2 members (Otto Skorzeny, 1955 1 Series), 89 guests, and 4 robots.
Topics128,031
Posts1,055,436
Members48,422
#68056 11/01/2006 10:59 PM
Hey guy's,my question is this.I have a 1961 or two chev fire truck with a five spd manual trans in it,and would like to incorporate it into a 1963 gmc napco Iam building,question is,is the first gear lower or the fifth gear higher.I have looked in the manual but mine does not show ratios.any info would be great thanks smile
Bent Happy Haulin!
TWO 1963 GMC\'s -- A shortbox and a NAPCO!
#68057 11/01/2006 11:11 PM
BENT,
My guess is that first gear would be lower. Unless a OD designated transmission, the high, or final gear will be 1.0:1 in most transmissions.
Are you including reverse as a gear to come up with five speeds? I think you usually only call out forward gears to come up with the number of 'gears'...four forward gears would be a four speed box.
Stuart
#68058 11/01/2006 11:54 PM
BENT,
Scroll down the page on this link, maybe it has something pertinent to your rig.
http://www.6066gmcguy.org/SM420.htm
Stuart
#68059 11/02/2006 4:56 AM
Some of the big trucks ran a 5 speed Clark trans. in them. I have a 71 manual that lists 7 different 5 speeds for the big trucks, 2 New Process',1 Spicer and 4 Clarks but I don't know how far back they go. My manual doesn't list the ratios either, sorry,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#68060 11/02/2006 7:05 AM
I've seen a web page on Clark 5-speeds that says some are OD 5th and how to identify those that are. I don't know how I found it.
Unless this firetruck was built to run on the highway its probably a 1:1 5th.
#68061 11/02/2006 5:35 PM
Thanks for the info guys,I guess my best bet is to get under and try and i.d the tranny.Does anyone know if the trans will be listed on the v.i.n,and if so where?
Bent Happy Haulin!
#68062 11/02/2006 7:03 PM
Years ago my brother had a 57 gmc 3/4 4x4 that had a 302 with a 5 speed. He was told the engine & trans was out of a dump truck. 5th gear was overdrive in this trans. I don't know what make the trans was.
#68063 11/02/2006 11:27 PM
Riding in the Passing Lane
There should be a tag on the side of the trans identifiing it.
1972 Chevy c10 Cheyenne Super
