| | | Forums66 Topics128,034 Posts1,055,547 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68056 11/01/2006 10:59 PM | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | Hey guy's,my question is this.I have a 1961 or two chev fire truck with a five spd manual trans in it,and would like to incorporate it into a 1963 gmc napco Iam building,question is,is the first gear lower or the fifth gear higher.I have looked in the manual but mine does not show ratios.any info would be great thanks  | | |
#68057 11/01/2006 11:11 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | BENT,
My guess is that first gear would be lower. Unless a OD designated transmission, the high, or final gear will be 1.0:1 in most transmissions.
Are you including reverse as a gear to come up with five speeds? I think you usually only call out forward gears to come up with the number of 'gears'...four forward gears would be a four speed box.
Stuart | | |
#68058 11/01/2006 11:54 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | BENT, Scroll down the page on this link, maybe it has something pertinent to your rig. http://www.6066gmcguy.org/SM420.htm Stuart | | |
#68059 11/02/2006 4:56 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Some of the big trucks ran a 5 speed Clark trans. in them. I have a 71 manual that lists 7 different 5 speeds for the big trucks, 2 New Process',1 Spicer and 4 Clarks but I don't know how far back they go. My manual doesn't list the ratios either, sorry, Scott | | |
#68060 11/02/2006 7:05 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I've seen a web page on Clark 5-speeds that says some are OD 5th and how to identify those that are. I don't know how I found it.
Unless this firetruck was built to run on the highway its probably a 1:1 5th.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#68061 11/02/2006 5:35 PM | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | Thanks for the info guys,I guess my best bet is to get under and try and i.d the tranny.Does anyone know if the trans will be listed on the v.i.n,and if so where? | | |
#68062 11/02/2006 7:03 PM | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Years ago my brother had a 57 gmc 3/4 4x4 that had a 302 with a 5 speed. He was told the engine & trans was out of a dump truck. 5th gear was overdrive in this trans. I don't know what make the trans was. | | |
#68063 11/02/2006 11:27 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There should be a tag on the side of the trans identifiing it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
