| | | Forums66 Topics128,065 Posts1,055,868 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | I bought two oil bath air filters at a swapmeet this past weekend. I plan to run both on a dual carb set up I have been working on. Does anybody have a pictures of a oil bath converted to paper or any experience with running oil bath air cleaners on engine not designed for them?
I don't think it will be a problem if I use a little lighter oil then recommended since each will have less air pulled threw them.
What do you think?
Joe
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | Thanks Tim, it looks like you just gutted the housings and glued in some support to hold a standard element. Thats what I was thinking but just couldn't picture it.
Joe | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Joe,
I did not do the conversion on the air cleaners. I bought them converted/painted with element from Tom Langdon (Stovebolt Engine Company) at a good price (made to fit Carter-Weber carbs).
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Joe,
I took an old oil bath air cleaner, pulled out the guts, and cut off most of the outer flange. This outer flange was visible from the outside just so it looked like the original oil bath.
I took the whole thing to Autozone and fitted it with a paper filter. I am sorry but the air cleaner went with the truck when I sold it. I don't know the filter number.
You may be able to do this and find the right filter. If this is what you are thinking.
Best of luck.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | On my oil bath filter I just took out the center, no cutting involved and put a Fram CA148 in. No fuss, no muss.
Ed
| | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | I am going to head over to the local parts house and see what I come up with. These are Studebaker Filters, or at least came on them. United Filter Company made them so the filters listed above probably won't fit if they are in A/C built housings.
Thanks for the idea's, Joe. | | |
