0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#680017 09/23/2010 6:30 PM
I bought two oil bath air filters at a swapmeet this past weekend. I plan to run both on a dual carb set up I have been working on. Does anybody have a pictures of a oil bath converted to paper or any experience with running oil bath air cleaners on engine not designed for them?
I don't think it will be a problem if I use a little lighter oil then recommended since each will have less air pulled threw them.
What do you think?
Joe
Joe H #680035 09/23/2010 7:47 PM
tclederman #680231 09/24/2010 3:37 PM
Thanks Tim, it looks like you just gutted the housings and glued in some support to hold a standard element. Thats what I was thinking but just couldn't picture it.
Joe
Joe H #680241 09/24/2010 4:20 PM
Joe,
I did not do the conversion on the air cleaners. I bought them converted/painted with element from Tom Langdon (Stovebolt Engine Company) at a good price (made to fit Carter-Weber carbs).
tclederman #680284 09/24/2010 9:06 PM
Joe,
I took an old oil bath air cleaner, pulled out the guts, and cut off most of the outer flange. This outer flange was visible from the outside just so it looked like the original oil bath.
I took the whole thing to Autozone and fitted it with a paper filter. I am sorry but the air cleaner went with the truck when I sold it. I don't know the filter number.
You may be able to do this and find the right filter. If this is what you are thinking.
Best of luck.
Dennis
oldbluetruck #680344 09/25/2010 2:15 AM
On my oil bath filter I just took out the center, no cutting involved and put a Fram CA148 in. No fuss, no muss.
Ed
Forty9 #680460 09/25/2010 3:49 PM
I am going to head over to the local parts house and see what I come up with. These are Studebaker Filters, or at least came on them. United Filter Company made them so the filters listed above probably won't fit if they are in A/C built housings.
Thanks for the idea's, Joe.
