1 members (joe apple),
110
Mod | | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Well, I've started the engine, bled the brakes and installed the tank so its time to think wiring. (1952 Panel with V8) I've read several "reports" from the search but wonder if anything new has/is taking place. I'm ready to order my harness but I want any updated info before I do. I would like to buy Rebel Wiring as its American made, but then there is XYZ and a couple others. Will you share your updated views please. ....oh, and how many "circuits" do you recommend as I will not be doing electric windows as it does make a difference on price. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I was so happy with the Hot Rod Wires harness I put in the '56 that I bought another for my '54 pickup. I had a Painless harness that I bought from a guy who gave up on his project. After looking it over I sold it at a swap meet and bought the second HRW one. I used the 12 circuit one. | | | | | Joined: Aug 2007 Posts: 116 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 116 | I bought the mr roadster 20 circuit from speedway motors for 149.00. Dont think i will need 20 circuits but i figured i want to do this once lol.. I started putting it in last week. All wires are marked with what they are for and the instructions are straight forward
Matt
http://www.flickr.com/photos/50657267@N08/sets/
1939 1/2 ton Resto-mod 1937 1 1/2 ton Is in the driveway
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Hi Alvin.....I used an 18 Cct. Painless Universal truck harness in my '40. I picked it up on E Bay for a good price. I think 12 Cct might be a little tight if you start adding lots of accessories. I found the Painless Tech guys really good to deal with when I got stuck. I can't recall what you are doing motor-wise on your panel, but Painless has all sorts of add-on modules for injection, fans, etc. | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | Hi ALvin, I bought my harness a couple of years ago from Classic Chevy for less than a c note. The only thing I thought could be better was the documentation, and even then it only took a few hours to do the rewire. That and the wires running under the 52 were unprotected. I bought some wiring loom, and have had no problems, Jimmie. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Any one have info and or experience on EZ Wiring or Keep it clean wireiing? | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Still hoping for help I want to order one or the other this weekend | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Gazim, I'll guess we can check out the ones recommended but I'm not "sold" on any particular one yet. I just checked a local hot rod shop that "says" theirs will work but they can't be specific. I'd like to save a few dollars but so far I've even ruled even them out. I think I'm just gonna spend the computer time and actually call a couple of them and see what they say! | | | | | Joined: Feb 2009 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 95 | Fellow wire nuts, No pun intended. I have used Ron Fransis,Painless,and Haywire. Painless is great but a few more $$. Ron F. for a few more $$. Haywire is the best bang for the buck.They are based out if Joplin,Mo and if you need an answer they can help and make the panels themselves. Just my opinion. I'd get at least a 18 ct unit. Bought a unit for my Burb a month ago from them.
Sully
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Will check out Haywire, Thanks. | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Hi Alvin,
Don't be afraid to build your own harness based on some other Chevy product. I used most of a '75 C10 front harness in my just completed'71 wiring. Get a wiring diagram on the doner and go to town. Don't let wiring scare you. I solder and heat shrink everything. Ground wires are your friend.
Considering your set-up, I would think you could use an S10 front harness easily.
best wishes,
Les | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Les, that would make since and I'm running a serpentine belt system with the brackets and alternator ect. My nephew has pretty much "volunteered" to do it. I'm not scared of it but I do think I'm getting lazy...or old...... or both  Thanks for the idea. Say hello to Sarah for Victoria and I. Oh, Les, the club had a cruise in at the Beacon last night. I had the Roast Beef A-Plenty and there was over 100 cars there along with an exhibition by the R&D Shag Club. Good event. You all would have loved it.
| | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | I'm not scared of it but I do think I'm getting lazy...or old...... or both Alvin its not that it's just that if you lay down on your back your eyes close | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Alvin,
The Beacon? You DOG! The city here wants to put High Speed Rail 100yds from our house. We may HAVE to move closer to you and The Beacon! ;}
Les | | | | | Joined: Jun 2010 Posts: 38 New Guy | | New Guy Joined: Jun 2010 Posts: 38 | Alvin, Gazim, What'd you guys go with, and any opinions yet? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Traeg, I have NOT order one yet. Still trying to decide on just what I'm going to do. I've used Painless, Rebel and another one or two over the years and have not really had any problems with them. Its been a while though and thats why I needed an update. I got side tracked on a couple other things on the panel and its sort of "in the wings" for now. Maybe after the stovebolt reunion next month I can order one. I'm saving my pennies for Kansas!!! I'll try to remember and come back here and update when I do.... and I'm interested in how Sullys works out from Haywire and what gazim thinks if he goes that route. I probably have a little more time before I actually wire it. I like to do a little "research" instead of waiting till the last minute. Thanks for checking in with us thou.....it reminds me to keep up the hunt!! | | | | | Joined: Jun 2010 Posts: 38 New Guy | | New Guy Joined: Jun 2010 Posts: 38 | I ask because I have to replace mine too- darn desert packrats. Here's what I don't understand, you can pay anywhere from $150 to nearly $700 (at LMC, see pg. 93 at http://www.lmctruck.com/icatalog/ca/full.aspx?Page=92) and honestly I can't tell the difference. Do I need a harness made specifically for my stock '57? I might, as I'm a complete noob at all this, and I've heard of troubles with leads being too long, too short, etc. I contacted Haywire and Ron Francis, and both assure me their less expensive kits will work- But in talking to some people in town they recommended going with Chevy Duty- only problem is Chevy Duty is no longer under that name- and I can't track them down. I'll start a new topic as I don't really understand the basics about what's needed in a wiring harness- so deciding who to buy from is a bit premature. But keep this thread posted with what you find with your new harnesses, and good luck! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Traeg - the $700 job includes a whole bunch of add-on bells and whistles, even a new ignition switch .... I would suggest that yes, you need a harness specifically for your TF truck, as it will have the correct lengths and layout and the correct connectors for gauges and such rather than a bunch of wires that need to be cut to fit and terminals added on .... OTOH, any of the vendors will have a good quality original style harness for the 55-59 at around $200
Bill | | | | | Joined: Jun 2010 Posts: 38 New Guy | | New Guy Joined: Jun 2010 Posts: 38 | Bill, when you say "vendors" are you referring to a Chevy truck parts vendor, or everybody- How about this harness from Haywire- which has been mentioned in the above discussion http://haywireinc.com/catalog/shopping_cart.php?sort=3a&osCsid=0d72ivo03dd748fcvhfdbntsf1like Haywire, Ron Francis has simply what he calls a "retro" Chevy Harness http://www.ronfrancis.com/prodinfo.asp?number=WR%2D85 But I'm wondering if these harnesses are going to require a lot of cutting/splicing- plus, they're not mentioning alternator vs. generator, column or dash ignition, etc. Thanks for all the help on this- | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I mean the Chev repro vendors, like the Stovebolt sponser here, basicly "plug and play" [or pray  ], using the original layout and connections with very little adjustment needed other than things like the rear wires which will fit the long frame so need to be cut back for the short, and maybe some additional things for updates or options like alternator, which should just be a different "charge system" small harness with the correct connectors any of the vendors that are wiring specific should have similar, but anything labeled by the number of circuits is aimed at folks wanting to add modern upgrades - you gonna have AC, power windows, power door locks, relays galore, elect fan, etc, etc? that's what the many circuit harnesses are meant for - if you want to put in a modern column with power steering, automatic and column ign, American Classic carries that style harness as well, with the modern fuse panel and switches [and way less than $700] I've gotten 3 original style repro harnesses from different vendors like this, all with the right connectors in the right place to fit in just like the original did, allowing good original bits like factory turn signals to be plugged right in - if you want a fuse panel [which would have been factory installed only with electrical options like radio], the original style is also available complete with correct wires to hook it in, no need for a modern replacement Bill | | | | | Joined: Jun 2010 Posts: 38 New Guy | | New Guy Joined: Jun 2010 Posts: 38 | Thanks Bill- very helpful. I had actually looked at the sponsors site (ACTP), but had looked under "electrical". Guess you have to scroll down to "wiring harnesses". In that same vein, try finding a steering wheel for a '57 on that site. Good prices, just need to update their website a bit, if you know anyone there, let 'em know. I definitely want to support the sponsor of this site as often as possible- the Stovebolt Forums are a great resource for newbies like me! Again, thanks for keeping me on the straight and narrow (and less expensive!) track in all my posts- I really appreciate it- this is definitely the style harness I should go with for now. Alvin and Gazim, I'm still curious how your projects end up- Gazim, I found this post regarding EZ Wiring from Rod and Custom: http://www.rodandcustommagazine.com/techarticles/0908rc_ez_wiring_harness/index.html | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | update? seems up to date to me - and I don't have any more contact with them than using their electricity to BS with folks here cuz of their generosity  maybe your problem is getting to the right list - just click "view/order parts" on the left of any page, then click the proceed button, then select your year and proceed again to the whole list this wheel? - it's where it belongs, in the 57, 58, 59 lists [it's the same for those 3 years], under Steering Column Items, down at "Steering Wheels and Horn Button Caps" there's an awful lot of parts to onea these trucks, just have to scroll the lists and think about how they might be cataloged - one of the reasons I use their online catalog as reference is they've got it well laid out and most things have accurate pictures rather than "artists conceptions" - their prices are comparable to most vendors, cheaper than some Bill | | | | | Joined: Jun 2010 Posts: 38 New Guy | | New Guy Joined: Jun 2010 Posts: 38 | umm.. yup, that wheel. right in front of my face and I didn't see it. fair price too, though now I'm thinking I'll try to repair mine first. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | not hard to fix an original wheel with epoxy putty and a re-paint, Eastwood I think it is, has kits and instructions
Bill | | | | | Joined: Sep 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 48 | I used a rebel wiring harness,9+3 model ,, got it direct from the owners of the company, had everything needed and instructions were excellent, it cost me 140, they sell everything you need, and he's always available if you have any questions, its not a big company so there's no long phone wait.. it was a good investment for the money.. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Hi Traeg, Haven't seen your name around much. We will have to change that. The wiring kit from E-Z is still setting on the bench I really don't want to take a chance of screwing something up when I have shows every weekend. I just bought some bitchin exhaust tips and am moving the exhaust from the roll pan to under the running boards th will come out in a 2x8.tip. Will get a pick if I get them done next week Nobody will notice if I have only one done.
| | | | | Joined: Jun 2010 Posts: 38 New Guy | | New Guy Joined: Jun 2010 Posts: 38 | I bought an original style wiring harness from Jim Carter- Could have paid less, could have paid more- wanted American made, and I didn't want to deal with cutting, splicing etc. I'll give an update when I get into it- Thanks guys, for all the help!- T | | | | | Joined: Sep 2008 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 137 | I bought a cheap repro from Classic Parts for like $175 or so. Worked perfectly. I can't see any reason to spend 4 or 500 on anything else, unless you want to start adding fuse blocks and multiple "extra" circuits. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Well its in. What a Bi=ch. If I didn't have help from 2 good friends I would have never made it. EZ wiring isn't EZ. The parts were all there and labeled properly. The directions left quite a bit to be desired. They were one size fits all from a John Deere to a Lamborghini.
| | | | | Joined: Jun 2006 Posts: 70 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 70 | I would recommend Classic Parts original type wiring harness for any electrical novice, like myself. Having never done anything like this before, I was really impressed how the wires were the correct length, connectors attached, and already inside insulators usually. It was pretty basic. No wiring included for deluxe heater, accessory juntion block, taillight pigtails, or turn signal switch. I'm about 1/2 way done. Problem is when the old wiring got torn out, I saw about 20 little jobs that needed done before wiring it! | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Hey Uncle Alvin! Well I really like my Ron Frances kit but I do not think the price is justified compared to others out there with near or identical quality. Painless looks like a Quality kit to me and from Gents I spoke with over the summer at some shows that used there product I dont think you would go wrong. Tim | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'm "leaning" toward the Rebel kit right now. I used the Painless in my 37 with no problems. I've looked at prices, kits and circuits till I'm half blind!! I'm going to call Rebel today and see what the deal is...and the 15% stovebolt discount. I'll keep you posted. Tim, tell Seth "uncle A" said hello  | | |
