6 members (Donf, Rustnut, Eisenholtz, TUTS 59, Hotrod Lincoln, 1 invisible), 61 guests, and 3 robots.
Topics128,203
Posts1,057,414
Members48,471
I bought this truck today and it has a few things it needs. For one it will need a frame paint. I was wondering what is best to use? I thought it was restored completely but it is not so now I want to finish it.
Brad
[IMG]http://i259.photobucket.com/albums/hh291/Ameritowruston/54chevy.jpg[/IMG]
I would use POR 15. It is the best stuff for the frame. People call it powder coat that you brush on. You can also just brush it on and will work great with the look of sprayed.
Kenny Broomfield
....I'll second the POR15. If you do a search on it you will find hours of reading!! Good stuff but be careful and follow the precautions and instructions.
POR-15
Big Bolt Forum Co-moderator
What do you think about Zero Rust. I have used that product and it doesn't have the health hazards of the Por-15. I bought it because it was easy to find where I shop.
1948 Chevy 2-Ton
Zero Rust is excellent, and as you say Super55, much less toxic than alternatives
Thanks Guys that was what I had in mind. I was just wondering if there was anything else out there but ya'll answered my question.
Brad
I used Zero Rust, on the Booms of the Holmes W45 Wrecker I just sold. I used the spray can version, & it was about 6 years old, & still holding up. I've also used POR 15, & as mentioned it's more toxic, & fades more with sunlight exposure.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Thanks Spanky I knew you would know. I still have your truck and I need to start working on it.
Brad
The Zero Rust will fade too, but you can put the clear coat on it that protects it from fading. I love the spray can stuff.
1948 Chevy 2-Ton
I've allways used Jasco prep and primer, It's a good first coat after everything is as clean as possible. It's got the consistency of water so it gets in the seems. It's toxic so be carefull, I used foam brushes and a deck sprayer to apply.You want to wait days before the next coat. It"s at Lowes in quarts
