0 members (),
138
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 88 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 88 | I bought this truck today and it has a few things it needs. For one it will need a frame paint. I was wondering what is best to use? I thought it was restored completely but it is not so now I want to finish it. Thanks Brad [IMG] http://i259.photobucket.com/albums/hh291/Ameritowruston/54chevy.jpg[/IMG]
| | | | | Joined: Feb 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 52 | I would use POR 15. It is the best stuff for the frame. People call it powder coat that you brush on. You can also just brush it on and will work great with the look of sprayed.
Kenny Broomfield | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....I'll second the POR15. If you do a search on it you will find hours of reading!! Good stuff but be careful and follow the precautions and instructions. | | | | | Joined: Sep 2008 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 137 | | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | What do you think about Zero Rust. I have used that product and it doesn't have the health hazards of the Por-15. I bought it because it was easy to find where I shop.
A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Zero Rust is excellent, and as you say Super55, much less toxic than alternatives
Bill | | | | | Joined: Apr 2009 Posts: 88 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 88 | Thanks Guys that was what I had in mind. I was just wondering if there was anything else out there but ya'll answered my question. Thanks Brad | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I used Zero Rust, on the Booms of the Holmes W45 Wrecker I just sold. I used the spray can version, & it was about 6 years old, & still holding up. I've also used POR 15, & as mentioned it's more toxic, & fades more with sunlight exposure. | | | | | Joined: Apr 2009 Posts: 88 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 88 | Thanks Spanky I knew you would know. I still have your truck and I need to start working on it. Thanks Brad | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | The Zero Rust will fade too, but you can put the clear coat on it that protects it from fading. I love the spray can stuff. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Feb 2010 Posts: 478 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 478 | I've allways used Jasco prep and primer, It's a good first coat after everything is as clean as possible. It's got the consistency of water so it gets in the seems. It's toxic so be carefull, I used foam brushes and a deck sprayer to apply.You want to wait days before the next coat. It"s at Lowes in quarts | | |
