4 members (originalchuck, TooMany2count, Chip O, Hotrod Lincoln), 78 guests, and 2 robots.
Topics128,024
Posts1,055,392
Members48,422
#67486 10/21/2006 1:52 AM
Hi Folks,
I have a question about GM's choice of engines in the 40's and early 50's trucks. If GM had better 6 cylinder engines with high oil pressure, why did they keep using the 216? It doesn't make sense to me to use an inferior engine when the GMC trucks had better engines.
Jeff
#67487 10/21/2006 2:12 AM
They did it in the 80's too. Remember the 2.8L?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#67488 10/21/2006 2:24 AM
The same reason GM had a chevy, pontiac, olds, buick, and cadillac. They covered the whole market that way. The cheapo (chevy) was basic while the snazzy (cad) had all the bells and whistles. Back then chevy and GMC were different trucks with the idea of capturing two segments of the market. It's called marketing. If the chevy had everything there would have been no market for the others.
Evan
#67489 10/21/2006 3:13 AM
Quote
Scott
What's wrong with the 2.8??? My S-10 has one, great engine. I get 25 mpg running 75 mph on the highway. Yeah, they have their quirks, like the oil leaks and starter problems (just put ANOTHER one on!), but overall their good in the correct application.
Bill Burmeister
#67490 10/21/2006 6:17 AM
The 216 was a much higher volume production line than the GMC. It was in all the Chevy cars, too. It worked just fine for the time. You didn't drive over 45 mph much in 1950. GM would have had to add another production line or two to cover the Chevy trucks.
There is really nothing wrong with the 216 as long as you know what to watch out for. They last a long time.
Paint & Body Shop moderator
#67491 10/21/2006 10:43 PM
Thanks! What does one watch out for to keep the 216 running for a long time?
Jeff
#67492 10/22/2006 12:20 AM
Ex Hall Monitor
Ex Hall Monitor
Change the oil and don't over-rev it. A fellow in the VCCA forum told me hotrodders of that era preferred the splash engine. It was more dependable than the high pressure oilers.
#67493 10/27/2006 4:03 AM
Basically if the motor works and sells for the times, your sell more with looks and appeal. The looks changed and the powerplant worked for the market sales so to save money (IMO) they left good enough alone. You can find some good reading in the Encyclopedia of Chevrolet Trucks by Don Bunn. Just picked up a copy and find it a good "libary" read.
1937 Chevy 1/2-Ton
#67494 10/27/2006 5:01 AM
The only real way to kill a 216 is to stretch the rods or starve the rod bearings for oil.
#67495 10/29/2006 8:40 AM
Like Tiny says ,, frequent oil changes (no filter remember) and easy on the gas , my 216 is still going after 66yrs.
GREAT ENGINE !!
OK,, so I wrecked a few in my youth,, but it was all 'cause I had TOO big a right boot, LOL.
#67496 10/29/2006 3:28 PM
Throw a tach on there if you're worried about killing it.
3000 RPM is just about the limit for a "Stock" engine. If you were to throw aluminum pistons in that old girl, you could probably bump the red line up to 3500 - 4000.
