0 members (), 116 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#674113 08/30/2010 1:43 PM
Not what you were thinking nono Just getting started on a 54. Don't know how long it has been since used. Noticed that the real axle seal had leaked on the brakes, so popped the cover on the rear. The oil in the rear has turned to Goo. Almost like tar. Is there something I can add to the rear end and drive for a few miles then drain that would help liquify everything?
Jeff
Diesel fuel, kerosene, ATF, all will do the job. Dig out what you can first and add some replacement gear oil to make up for what you dug out. It shouldn't take long to soften up.
Joe
I drained the oil in mine, put it on jack stands, filled with half kerosene and half 30 wt motor oil. Left the halogen light shining on it for a few hours to warm it up. Ran the truck on the stands for about ten minutes. After draining I pulled the inspection plate off of the back, and brushed/ rinsed with kero. Put 'er back together, filled with oil, changed after a hundred miles.
Basically, what Joe said, but I've had a whole lotta coff-ay.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
I guess I would check the bearings and races for replacement while I was at it.
