| | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 13 New Guy | | New Guy Joined: Aug 2010 Posts: 13 | Not what you were thinking  Just getting started on a 54. Don't know how long it has been since used. Noticed that the real axle seal had leaked on the brakes, so popped the cover on the rear. The oil in the rear has turned to Goo. Almost like tar. Is there something I can add to the rear end and drive for a few miles then drain that would help liquify everything? Thanks, Jeff | | | | | Joined: Feb 2000 Posts: 5,208 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,208 | Diesel fuel, kerosene, ATF, all will do the job. Dig out what you can first and add some replacement gear oil to make up for what you dug out. It shouldn't take long to soften up.
Joe | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I drained the oil in mine, put it on jack stands, filled with half kerosene and half 30 wt motor oil. Left the halogen light shining on it for a few hours to warm it up. Ran the truck on the stands for about ten minutes. After draining I pulled the inspection plate off of the back, and brushed/ rinsed with kero. Put 'er back together, filled with oil, changed after a hundred miles.
Basically, what Joe said, but I've had a whole lotta coff-ay. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I guess I would check the bearings and races for replacement while I was at it. | | |
