5 members (55shaker, GA Boy, Oswald, 50Chevy3100, 1 invisible), 59 guests, and 5 robots.
Topics128,180
Posts1,057,165
Members48,465
I have a 49 GMC 3/4 ton truck which I believe the commercial diff in it. It has 8 hole wheels. Is there anyone that can give me some info about swapping out the 3rd member to about a 3:42 gear. My diff that is in it now is not a enclosed driveshaft. It is enclosed from the trans to the carrier brg, and open from the carrier brg to the rear end, all stock. Currently it has 4:56 gears.
I found a set of 4:11s out of a late 60s Chevy 3/4 or 1 ton, these were in the trucks with automatic trans. I have heard that the same vehicle but a Suburban had a ratio in the 3s. Best of luck. Oh BTW I ran a wanted ad here on the bolt and found my gears.
1946 1/2-Ton Chevy
Joy Offline
Medic8492, Welcome to Stovebolt. If you go to Engine and driveline shop you will get a lot more help and as Jim said go to SwapMeetto see if you can buy some parts.Just going to General truck forum, you will be able to discuss this with more guys. Good luck!
Welcome to the Stovebolt Medic8492. Your are now in good hands!!
Hey thanks for the info.
If it is an Eaton rear end, I don't believe you can get anything below 4.11 My 72 K20 suburban has that combination.
Maurice
72 Suburban K20 350/T350/HO52
Thanks for the info.
