6 members (3B, Shardean, TUTS 59, Joe H, Otto Skorzeny, RLB), 115 guests, and 3 robots.
Topics128,030
Posts1,055,430
Members48,422
#669464 08/11/2010 4:00 AM
Y
Y Offline
When I sub-framed my 53 3100, it lowered the front about 6". Thats a little more rake than I wanted so I lowered the rear about 2". My question if I lower the rear much more where is my pinion angle going? Will it ruin the U-joints? I assume there a minimal amount of pinion angle required? Thanks, Phil
If you do a search you'll probably find hours or reading on pinion angle. I also think ther eis a tech tip here about it as well. Just check the angle you have. I believe the angle should be about 2 degrees negative. Some say check the angle on the engine at the starter, some say transmission ect ect. I check mine with the starter then go to the rear end and set it.
I think the "officially" the angle should be between 1 to 3 but I'm sure someone with a better memory than mine will chip in here. Good luck.
Achipmunk #669526 08/11/2010 1:30 PM
...I think there is a tech tip here about it as well...
This Tech Tip on Driveline Set Up ??
And from that Tech Tip
Quote
Most people have a hard time understanding how a driveline should work. Therefore many people who think they know how to set it up are confused. I have found that the best way for someone to understand how it works, and how to set the angles, is to read the instructions.
There are some excellent manuals (instructions) linked in the tip.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #669613 08/11/2010 8:27 PM
J Online: Content
As long as each u-joint has some angle, 3 being the most, and that includes up and down and side to side, then you will be all right. From what I have read, if the transmission to driveshaft angle is about 2 degrees, then the driveshaft to pinion should also be about 2 degrees. This is where the angle finders come in handy. The angle of motor and pinion to the ground makes no difference, you want to know the angle between the driveshaft and each end. A u-joint needs some angle so the inner bearings get worked around, if its straight, the bearings just get looser as they dig in.
Joe
Joe H #669615 08/11/2010 8:36 PM
3 to 5 degress down .When u set the engine in put a level on the top of the intake manifold , carb removed!Close to level is better for a carburated engines base line installation It should be close to 0 degress. The truck should be assembled as much as possable all weight on it so these numbers dont change much.There can be a lot of factors leaf springs coils what vehicle is built to do drive ,race ect.
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
Originally Posted by webstershotrods
3 to 5 degress down .When u sent the engine put a level on the top of the intake manifold , carb removed !It should be 0 degress. The truck should be assembled as much as possable all weight on it so these numbers dont change.
I disagree with the first part of your explanation.
After rechecking the Spicer Driveline manuals I can't see how the engine being level or not makes a difference, obviously you don't want it standing up on end, but 0 degrees or 5 or even 10 is not important.
As Joe mentioned above it is important to have the engine and the pinion parallel. The engine or pinion angle in relation to horizontal has no effect on the driveline, the relationship between the components of the driveline is where it matters.
Having the truck as close to final weight as possible and assembled when you measure and correct the pinion angle is an excellent point not to be overlooked.
Grigg
---All pictures---
Grigg #669691 08/12/2010 1:34 AM
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
If it's 0 at rest, it remain 0 only until you try to pull any load, then the pinion nose rises. How much nose down depends on suspension stiffness, engine power, max load, etc.
panic #669742 08/12/2010 4:16 AM
With the weight of the engine, and everything attached to the engine that is going to be attached to the engine, raise the vehicle up being sure that the weight of the vehicle is on the axles. Put an angle finder on the bottom of the starter and get that angle. Next put the angle finder on a flat portion of the pinion. Turn the pinion until the angle finds the same angle as the one on the starter. That's it. You can buy angle finders for a few bucks at Harbor Freight Tools.
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
J Online: Content
You had enough input yet! Heres a bit more, use a tie down strap and pull the axles down if you don't have weight on the chassis, it will get you pretty close.
The main thing is to not set the driveline in a straight line to the motor or axle.
Joe
Neither parallel, horizontal, nor "level" matter.
BTW: the carb flange mount is not always parallel to the ground, or to the crankshaft.
Grigg #669823 08/12/2010 1:45 PM
Has some broken links
Use this new link for the Spicer Driveshaft Installation Guide
and this link for the Spicer Driveshaft Application Guidelines
Sorry about that,
And in the future the publication number should stay the same and can be searched for on the Roadranger website if the direct links fail again.
Grigg
---All pictures---
Grigg #669850 08/12/2010 3:34 PM
Grigg, thanks for the link, they are a great referece as I am chasing down a suspected driveline vibration.
thx again
72 Suburban K20 350/T350/HO52
Grigg #669855 08/12/2010 4:33 PM
Grigg,
Those Dana-Spicer pdfs are very good. Thanks much. The other "Links" do not seem to work; it seems that if one uses the name "Links" for a link, it goes to the Stovebolt Links, regardless of the writer's intention. Same if one uses Tech Tips for a name, I think.
Hoyt
hoyt #669857 08/12/2010 4:36 PM
Hoyt - that's a "feature" grin of the forum software for most of the 1inks across the top of the page, you can subvert it easily by modifying the words a bit
hoyt #669900 08/12/2010 7:02 PM
Originally Posted by dckdgrs
Grigg, thanks for the link, they are a great reference as I am chasing down a suspected driveline vibration.
thx again
Originally Posted by hoyt
Grigg,
Those Dana-Spicer pdfs are very good. Thanks much...
Hoyt
Y'all are welcome, and thanks for looking at them.
As you can see they are invaluable and cover pretty much every driveshaft question with real answers and figures, not hearsay and guesses.
I wish more folks would read through them, at least look at the pictures.
Grigg
---All pictures---
Grigg #670169 08/13/2010 6:45 PM
I owned a driveline shop and built a lot of drivelines as many of you know. We always used he Spicer information as our guide (they trained us) and never had any problems, at least no one ever brought a shaft back to my shop complaining about it. We build car, truck, off road, racing and heavy equipment drivelines and the same basic rules apply to all. It is Gospel as far as I am concerned. I've read a great deal of stuff both here and in numerous magazines written by people who didn't understand the issue. Just refer to the Spicer link that Grigg posted and you will have no problems if you follow the instructions. Really pretty basic and simple stuff.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #670257 08/14/2010 12:49 AM
Y
Y Offline
Just wanted to thank everyone that responded to my post, and for the information provided.
