1 members (78buckshot), 38 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#663636 07/19/2010 3:39 PM
My '53 3600 has never had defrost outlets installed before. I purchased a heater and defroster assembly from classic Parts (#68-991A). Are the outlets attached with sheet metal screws or nuts and bolts? Nothing came with them.
The second question is whether they attach in such a way as to aim toward the firewall or toward the cab interior? I have everything out of the dash at this time and don't want to put them in one way and have to take stuff out again to do them the oposite direction.
Thanks for any help.
"It wasn't broke but I still decided to fix it. Now its broke"
I really love my coon hounds
Pics at http://s982.photobucket.com/albums/...0truck/53%20Chevy%20truck%20Sept%202010/
My second question should have been whether the hose end of the defrost outlet aims toward the firewall or the cab interior.
This was a post I made a while back that may help. They attach with a sheet metal screw on one side (you can see the hole in the dash) the other side attaches with a clip they either than face straight down for hose attachment or they turn into the firewall some have two screws for attachment and no clip but they pivot for ease of attachment one side has a full hole the other a slot.
Two styles of 1954 vents both made of aluminium one type straight the other reverse bend see pictures:
http://good-times.webshots.com/photo/2586236450102454676qRPcYh
http://good-times.webshots.com/photo/2021907660102454676cpkuJb
Next there are at least two styles of sheet ducts: 47-51 style:
http://good-times.webshots.com/photo/2405252410102454676ppisPX
52-53 1/2 ducts:
http://good-times.webshots.com/photo/2809720060102454676gVgVNT
http://good-times.webshots.com/photo/2653102730102454676PXUNwF
Then to add even more confusion I have seen them with and without these black spacers (usually on 1947-1950 trucks).
http://good-times.webshots.com/photo/2661175600102454676CudWvK
http://good-times.webshots.com/photo/2246331650102454676MRFRlr
The driver side kicking right a bit depending on the style.
_________________________
1950 Chevrolet 3/4-Ton 3600
http://community.webshots.com/user/RugerWSM?vhost=community
Brad,
The ones I received are plastic and have the neck bending 45 degrees and not canted off to either side. I see two small holes that can receive sheet metal screws. I will aim the necks toward the firewall.
...my GUESS is it may have something to do with what kind of heater you have???? I don't have both to compare but from looking at the pics...and at the ones I have its seems mine would "kick" toward the center of the dash rather than toward the firewall??? I ask basically this same question a while back and received a few pics from guys.... I haven't installed them yet but...from the looks of Brads pictures I have the 47-50, with the black "band" around them, on my 52 panel.... and I honestly think mine is original to the panel. They both have the black spacer band around them.
I guess I'll see what makes the most "common sense" when I put the heater in!!
John,
Have you called Classic Parts for assistance? As you know, the heater you bought is an aftermarket heater assembly and its parts are different from either of the GM optional heaters available in 1953. The outlets/ducts that came with the Classic Parts heater are (from what you describe) different from the outlets/ducts that are used in an original heater set-up.
By the way, the original ducts for recirculator and air-flow (fresh air) GM heaters were the same in the same years, but they were different from year to year during Advance-Design years (probably different in 54/55 due to cab/windshield change but might have been different 53-55 due to a change in fresh-air/air-flow heater?). None of the information in this paragraph is pertinent to you - Classic Parts should know how their ducts/outlets should be installed/orientated.
Classic Parts said that they did not know which way they mounted. The guy (Adam I think) just picked one of the two positions and said "try it". Not a good answer. I had called them before I made the first post for help.
If after I try them, I may have to look for stock ones to hook the new heater up to. Then I'll have to pull out the whole dash mess to install them. Ugh!
Ugh is right, John.
They should be ashamed.
Moderated by  ndkid275, Phak1
