3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#659029 07/02/2010 3:03 AM
Ok , I need a little help here. I have disc's on all four corners & a firewall mounted booster/proportioning valve. Problem is the front brakes are sticking. Bled the brakes last week and have good pedal pressure but the front brakes don't seem to be disengaging. Any ideas?
Robert C.
I'm a Genius in the making.
1950 3600
First thought would be faulty or kinked hoses. Try pushing the piston back into its bore. it should go in with very little force. If it doesn't, loosen the bleeder. If it goes in free, then the hoses are the culprit.
Bill Burmeister
LONGBOX55 #659046 07/02/2010 4:06 AM
Could have the brake pedal rod adjusted up too tight,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Scott
Robert, I saw your post in the ADTruckers(HAMB), I agree with Scott on this one too!
An over-adjusted pushrod will retain pressure to the front brakes,being the first circuit to activate,resulting in overheating and subsequent expansion/binding.
You also don't want to boil your brake fluid. drive
More pix on Flickr.
1 Offline
Scott
I agree with they said ! Im "still" having problems with mine Robert ! Im coming up with something better as we speak. "Thats the third lil goofy chrome booster in a year and a half" It's getting a little better but they are still giving me trouble.
But... Im sure getting better at pulling that master cylinder... (keep the wrench's in my glove box)
Keep us informed on what you came up with !
Todd
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
1Bad51 #659513 07/03/2010 8:36 PM
I don't think it's the M/C. It did the same thing last year when I had it running briefly. All components were new, including the hoses and calipers. It has sat up however for a number of years as I piddled with it. As I mentioned before I just swapped out the M/C recently. It's the same style but it came with a proportioning valve. I think the calipers have gone bad from sitting so long. Just bought a set to install but got side tracked by my dog. He got out of the yard yesterday morning and was missing all day. He came back home that evening and was is awful shape. Looks like he was attacked by a pit or two. There are huge chunks missing from all four legs with his back legs being the worst. His face is all torn up as well. Gotta play doc for awhile.
Robert C.
1950 3600
Firstly Robert,I hope your dog makes a good recovery.
Assuming you're happy with the M/C you maybe right about the caliper pistons sticking.
I try to make a habit of pumping the brake pedal every few days,as mine has been sitting for a while too.
This will hopefully avoid the same problems you seem to be having.
More pix on Flickr.
Problem solved!! Got a chance to install the calipers and that took care of the problem. Now on to the engine. Gotta figure out why it's running so crappy!
Robert C.
1950 3600
