2 members (78buckshot, IHPWR), 88 guests, and 1 robot.
Topics128,024
Posts1,055,395
Members48,422
#66075 09/20/2006 12:00 AM
I need to replace the trans pan gasket on my 350 tranny because it leaks. Is there a sure fire way to be sure it won't leak after I replace the rubber gasket? Any special sealants? What is the torque spec for the bolts? Thanks.
#66076 09/20/2006 12:50 AM
Make sure that you get the crush resistant gasket, it has small metal sleeves in each bolt hole to prevent over torqueing. Just make sure the lip of the tranny is clean and the pan surface is flat, around the bolt holes is a critical area.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
#66077 09/20/2006 1:16 AM
I like the ATP brand gaskets best, they aren't rubber, but they hold up well. I make sure the gasket area on both the pan and trans are clean and dry. I use a nut driver to tighten the bolts, and make sure the pan is flat around the bolt holes. No sealer.
#66078 09/20/2006 2:00 AM
They are still available from GM,,they don't leak, they are some kinda paper but very thick. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#66079 09/20/2006 4:04 AM
Use an aluminum pan for rigidity,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
