1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#66075 09/20/2006 12:00 AM | Joined: May 2006 Posts: 12 New Guy | | New Guy Joined: May 2006 Posts: 12 | I need to replace the trans pan gasket on my 350 tranny because it leaks. Is there a sure fire way to be sure it won't leak after I replace the rubber gasket? Any special sealants? What is the torque spec for the bolts? Thanks. | | |
#66076 09/20/2006 12:50 AM | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | Make sure that you get the crush resistant gasket, it has small metal sleeves in each bolt hole to prevent over torqueing. Just make sure the lip of the tranny is clean and the pan surface is flat, around the bolt holes is a critical area.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
#66077 09/20/2006 1:16 AM | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | I like the ATP brand gaskets best, they aren't rubber, but they hold up well. I make sure the gasket area on both the pan and trans are clean and dry. I use a nut driver to tighten the bolts, and make sure the pan is flat around the bolt holes. No sealer. | | |
#66078 09/20/2006 2:00 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | They are still available from GM,,they don't leak, they are some kinda paper but very thick. Brian | | |
#66079 09/20/2006 4:04 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Use an aluminum pan for rigidity, Scott | | |
