2 members (Peggy M, Otto Skorzeny), 97 guests, and 2 robots.
Topics128,052
Posts1,055,774
hey guys.
OK, here is what I got: 1957 truck dual 1bbl Carter W-1's on a 235cui. Fenton setup.
Everyday on initial start-up, just hit the starter and she turns right over and runs like a top. But, after running her around town for a bit and I get back in to start her, she eventually starts, but she is flooded. Much more revolutions till she kicks over than when she has been sitting for a while. I'm flooding...right? If yes, solution? ohwell
Carburetion specialist
The Carburetor Shop
thanks for the tip. That write up was very informative.
So, basically this is just something I have to deal with, and is 'normal'. Still I wish there was another way. Oh well. I'll put up with it. My straight 6 dual carbs are worth it!! thumbs_up
Riding in the Passing Lane
You might have too much fuel pump pressure. Check the pressure & if so put a regulator on it. The heat might be causing the fuel to boil. You might need insulators under the carbs.
1972 Chevy c10 Cheyenne Super
I have been dealing with the same issue with three carburetors, Starts right on cold engine, and after it sets for a hour, its the 15 minutes stops that it won't start. I have tried lowering the floats, but that leans it out where it duns like crap, I have a regulator set to 2 psi fuel pressure, and tried the isolators under each one. Nothing really helps much other then setting them lean. I learn to live with it. Not hitting the throttle helps, but its not the cure. Once started it runs great so I don't worry about it.
Good luck with yours, Joe.
